Old 10-26-2002
MASTON MASTON is offline
Senior Member
MASTON is on a distinguished road
.BUN problems in cakewalk 9
OK,
I'm making my first back-ups using .bun files (cakewalk 9.0, win98, notSE) and I save it as a .bun and then reload it and I get
'general error', and it wont open....
thats not a very good back up is it...
so i try some other files and some are Ok and some aren't...
then I take the offending files and kill one or two tracks in the wrk file and then save it as a bun and it reloads fine....
so anybody know what's going on...and how to fix it
is there a patch??
Maston
Old 10-26-2002
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
I think Cakewalk patched PA9 up through 9.03. Is that the version you're running?
Don't know what your problem might be, but you are very wise to check the files before deleting your .wrk files.
I suspect you could have a misbehaving plug-in. When you delete a track and then it seems to backup ok, is there a plug-in patched onto the track you deleted? Does there seem to be a rhymye or reason as to what works - i.e., is the same plugin on all the tracks you delete when you can get the .bun to work?
Old 10-26-2002
Senior Member
I'm running pa 9.00, I'll try and get an upgrade/patch
no, no plug-ins on tracks I delete. pattern seems to be delete the last track, or last two tracks, and then its OK.
oh yeah, and I've found another problem now:
on another track it says, 'please delete events containing missng audio before saving as a bundle'
cept there is no missing audio?
Maston
Old 10-26-2002
Senior Member
OK,
dachay: Updated to 9.02, and the buns load back up no problem now. Cool...
still getiing that 'cant save cos of missing audio problem' though on one track...any ideas
cheers
Maston
Old 10-26-2002
laptoppop's Avatar
laptoppop laptoppop is offline
Musical Technogeek
laptoppop is on a distinguished road
Its been a while since I've used PA9 -- I'm using Sonar2.1 now, which I highly recommend as an upgrade. In the meantime, if I recall correctly, there is a "search" function where the program can hunt around and try to find the missing audio. I know there is in Sonar, but I thought it was in PA9 as well.
Good luck,
-lee-
Old 10-26-2002
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Though not a fix for the bun problem, you still could make a copy of you project and data files to a second safe place untill you get the bug worked out. It'll probably be a bit bigger, but still a good safety.
Good luck.
Wayne
Old 10-28-2002
Randell Marks Randell Marks is offline
Newbie
Randell Marks is on a distinguished road
Missing Audio...
I just encountered that this weekend. Somehow, there is a track that IS missing audio. It appeared on mine as a blank area between two waves. Here's how I found it:
1). Save the file under another name so you can play with it.
2). Figure out which track is offending, like you did before.
3). When you have found the track, look for the dead areas.
4). Solo and play the dead areas and see if anything funny happens.
5). When the dead area is found, record some "dead air" into the spot and try saving it.
Good luck.
Randell
Marks Brothers Productions
