Go Back   Home Recording > User Forums by Brand > n-track User Forum
     Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 10-22-2002
rpe's Avatar
rpe rpe is offline
NM - Land of Excrement
rpe has a reputation beyond reputerpe has a reputation beyond reputerpe has a reputation beyond reputerpe has a reputation beyond reputerpe has a reputation beyond reputerpe has a reputation beyond reputerpe has a reputation beyond reputerpe has a reputation beyond reputerpe has a reputation beyond reputerpe has a reputation beyond reputerpe has a reputation beyond repute
Question What is an acceptable noise floor........
using n-track, tracking a mic'd amp into a mixer then to the soundcard? It probably depends on a lot of different factors in the signal chain but I'm wondering what is levels you are getting when you view the n-track record vu-meters.
thanks,
rpe
Old 10-22-2002
Treeline's Avatar
Treeline Treeline is offline
Don't Give Him Coffee
Treeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond repute
I get different levels based on the computer. My Dell bigvanillabox has a nearly silent floor; the only grunge is from signal I toss in - may pick up something from a mixer, or the parakeets in the next room, and so forth. But when I tried it on my laptop - with its "soundchip" - UGH. -40dB without signal. No point in going any further with that.
Originally Posted by chrisharris View Post
I love Treeline. He's so polite when he's cutting a hole in your abdomen and pulling your intestines out to play air guitar with.
Old 10-22-2002
rpe's Avatar
rpe rpe is offline
Thanks Tree
I'm trying different attenuation options (amp, mixer, sound card gains) to discover the lowest noise level while still getting a strong enough signal.
rpe
Old 10-24-2002
Treeline's Avatar
I've always been told to start with a strong signal and cut progressively through the signal chain so as to avoid adding noise at each stage. So my mixer usually has a pretty high trim setting and I shut off anything not absolutely necessary to run raw signal into the computer. I'm dealing with borderline equipment, so it's a challenge and sometimes the track is noisy as the dickens.
But if the preamps are kicking in with greater noise after a certain attenuation level, maybe there's a way around it. I've found the virtual preamps in the n-track effects units are pretty good. So one experiment might be to run signal into a mixer with with the channel trims down a bit ( like a third or so ) and see whether boosting signal with a reverb or short echo virtual preamp later in the chain improves the sound floor or makes it worse.
I've also been experimenting with volume envelopes in n-track to cut any signal not necessary for a mix. It's a pain but it helps. I haven't learned much about compression yet (other than reading everything here I can find!!) and that'll be the next thing to tackle.
But I guess there's just no substitute for a good mic and a good preamp, any way you look at it...
Old 10-24-2002
shackrock's Avatar
shackrock shackrock is offline
1K Silver Member
shackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond repute
DELTA 44.
if i got no inputs there, but i select monitor - i get -85db
now as for my room, it is a terrible room, so lets just say its noisy.ha
Scott Solo
