Go Back   Home Recording > User Forums by Brand > n-track User Forum
     Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 10-12-2002
bdemenil bdemenil is offline
Force of Nature
bdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond repute
3.1.7 - Problems
Problem #1
Bugs keep cropping up with song files getting corrupted. I'll save a file, quit, and then when I try to open the song I just saved the program will not open it successfully. i thought the problem was with loading plugins, but then it occurred again with a song in which I hadn't even loaded plugins.
Problem #2
Something wrong with track-offset compensation. When using WDM drivers, program will sometimes put new tracks temporally ahead of the originals (seems to depend on driver's buffer settings). I observed this problem when beta testing new delta drivers from maudio (the old maudio drivers had a big track-offset bug, so it's worthless to test with them). The new drivers worked fine with all the other apps i tested, as well as with ntrack 3.0.3. The new drivers aren't available yet, but I bet if you're using WDM with other soundcards you'll have the same problem.
Considering these 2 major issues, I would advise against using this version of ntrack. Hopefully the next one will be better.
Old 10-12-2002
shackrock's Avatar
shackrock shackrock is offline
1K Silver Member
shackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond repute
post these on the NTRACK board at fasoft...
www.ntrack.com - then go to disscussion.
flavio would love to see these bugs.
Scott Solo
Old 10-14-2002
benson812 benson812 is offline
Newbie
benson812 is on a distinguished road
I think the track offset problem is happening for a few others too.
3.1.7 sounds good,but I think I'll wait for the next build.
It seems that each new version needs at least a month to "settle in".
v2.3 still seems to be the most stable judging by posts.
(I've not tried it,but do have a copy).
It actually sounds almost uncrashable......those that've used it,is this true?
Does it run on XP?
Are the newer versions features that much better?
I did get v3.1.4 (i think---they change so often) to work so well,I couldn't crash it,even when i tried!!!
I've now just built a dual boot system (2 x XP), in the hope that'll help stability,one set up dedicated just to music.
Haven't actually tried it out yet though.
Like a lot of ppl,I really like n,and although the midi side is a bit *crap*,it's actually getting a lot better.
The rest of the prog is really intuitive,and easy to get the hang of....I'm always suprised as to what it can do.
Old 10-14-2002
Slackmaster2K's Avatar
Slackmaster2K Slackmaster2K is offline
Gone
Slackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond repute
Ben, I emailed Flavio about the original m-Audio WDM track offset problem back when we first started discussing it. I wonder if he didn't write some compensation into n-Track?? Wouldn't that be odd...he didn't mention it in the revision history, although I have a feeling he doesn't mention everything.
Slackmaster 2000
Slackmaster 2000
Old 10-16-2002
Force of Nature
Following Flavio's advice, I tried unchecking the 'keep audio devices open' box in advanced device preferences (default is checked). This solved the track offset problem.
The other problem, I now realize, was due to an ntrack config file existing in the project directory. This sometimes happens - I think if you launch ntrack from an existing song file the first time after you install it. After i deleted the file, along with a directory named 'VST Plugins', I was once again able to open my song files without error.
So the 2 initial bugs I reported are correctable. I will post new ones if/when I discover them.
Ben
