Go Back   Home Recording > User Forums by Brand > n-track User Forum
     Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 10-09-2002
Rusty K's Avatar
Rusty K Rusty K is offline
1K Silver Member
Rusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond repute
Input volume problem
Hello,
I'd been having problems with 3.1.5 so I just downloaded 3.1.7. I believe that it's running much better however I'm again experiencing recording volume clips for no apparent reason.
Mono is ok but stereo to two tracks is impossible to bring the level down. I had this same problem with 3.1.5 and I posted about it either here or at FAsoft. I can't remember what the damn fix was and searching for my post at FAsoft is a pain.
Does anyone have a clue as to what my problem is?
Thanks,
Rusty K
Old 10-09-2002
Rusty K's Avatar
1K Silver Member
Ok...
I found my previous post on this subject but it didn't answer my question about the input vol. clipping. I'm thinking that the problem simply dissappeared on it's own as I began to tweak my system to clear up many problems in functionality.
Anyway I don't want to revert to default settings because the program is otherwise responding much better than before.
If I can clear up this problem I may be back in business.
Thanks,
Rusty K
Old 10-09-2002
Rusty K's Avatar
1K Silver Member
update!
Ok again...
I've been able to record just the signal that is causing the clip. It sounds like a metronome. It's loud enough to record at level with the input faders dropped to almost "0". It's there all the time when I'm in either stereo modes. I can record flawlessly in mono.
What could be causing this?
Other than this problem, 3.1.7 is performing just fine.
Rusty K
Old 10-09-2002
Slackmaster2K's Avatar
Slackmaster2K Slackmaster2K is offline
Gone
Slackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond repute
umm...is the metronome turned on?
Slackmaster 2000
Old 10-09-2002
Rusty K's Avatar
1K Silver Member
Hey Slack,
I opened metronome and could see nothing weird. It sounds like a metronome but I'm not absolutely sure that's what it actually is. It could be some kind of signal that's just cycling in a pattern. Whatever it is it's there the minute I click either stereo record mode.
I'll go look around again.
Rusty K
Old 10-09-2002
Rusty K's Avatar
1K Silver Member
Input VU meter shows the signal there but I can't hear it until I hit the record button.
If I depress the "Live" button I can then hear the weird signal.
Rusty K
Old 10-09-2002
Gone
Open up the metronome and hit test, just to see if that's what it is. Probably not though...very odd...
Slackmaster 2000
Slackmaster 2000
Old 10-09-2002
Rusty K's Avatar
1K Silver Member
I've hit test.....but what is it supposed to do? Am I supposed to hear it or what?
The button just changes from "Test" to "Stop" until I depress it again. Could be I had my analog out muted when I tried I'll try again.
Ok tried again. Unchecked "mute metronome". PC speakers were checked but the sound came through the modem speaker not my headphones or my monitors.
Now I'm almost sure this sound is not the metronome. It's different but in steady intervals.
Update!
I just found the message to Flavio pertaining to this problem back when I downloaded 3.1.5. Unfortunately I had to submit the query to Flav again as I stupidly deleted his "fix".
I'll be sure and relate what he has to say when he responds.
Rusty K
Old 10-10-2002
Rusty K's Avatar
1K Silver Member
Ummmm....so far Flavio suggests reverting to default settings. I'm scared to do it yet since the program is smooth otherwise.
Rusty K
Old 10-14-2002
Rusty K's Avatar
1K Silver Member
I'm like in limbo here!
I have posts at FASoft and with Flavio about this @#$%^& problem.
Here's a link to the offending signal that is present whenever I select either stereo mode for recording.
http://r-dkeith.home.texas.net/Mp3
Take a listen to the whole section. It's sounds like a metronome but if you listen on you will hear it fade and then come back. That is what the signal does throughout.
Rusty K
Old 10-14-2002
Rusty K's Avatar
1K Silver Member
Update!
I've been on the phone with my soundcard mfg. this morning. I downloaded a diagnostic app from their website.
My soundcard is functioning just fine!
I'm freaking stuck. I can't go back and and I can't go forward. This really sucks and it's wasting hours of my time.
It kind of gives a more realistic and rational meaning to "inexpensive".
Rusty K
