Old 10-08-2002
theletterq theletterq is offline
Dedicated Member
theletterq is on a distinguished road
Question Balanced/Unbalanced Monitor Inputs
Quick little question. My DAW has unbalanced monitor outputs. My monitors have combination XLR/TRS (balanced?) inputs. Can I simply run an unbalanced cable from the DAW to the monitors with no problems (other than some signal loss)? I still get a little confused about the balanced/unbalanced thing. Thanks...
Old 10-08-2002
StevenLindsey StevenLindsey is offline
Force of Nature
StevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond repute
unbalanced will work fine as long as the cables aren't too long. If you get noise you might try using TRS cables but you probably won't. I use unbalanced lines and they work fine.
Old 10-08-2002
SS454's Avatar
SS454 SS454 is offline
Dedicated Member
SS454 has a reputation beyond reputeSS454 has a reputation beyond reputeSS454 has a reputation beyond reputeSS454 has a reputation beyond reputeSS454 has a reputation beyond reputeSS454 has a reputation beyond reputeSS454 has a reputation beyond reputeSS454 has a reputation beyond reputeSS454 has a reputation beyond reputeSS454 has a reputation beyond reputeSS454 has a reputation beyond repute
You have to solder the low(pin #3), to the ground (pin #1) on the unbalanced side of the cable. It's really easy to do.
THIS MACHINE KILLS HIPPIES
Old 10-08-2002
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
Re: Balanced/Unbalanced Monitor Inputs
Most likely the trs is bal/unbal so it shouldn't matter if you want to use an unbalanced cable.
Old 10-09-2002
Force of Nature
you don't need to solder anything. just get two instrument cables and plug them in. ( or two radio shack rca / 1/4" mono cables depending on the outputs of your daw. ) No need to get technical. If you want to get snazzy, you can get gold plated plugs.
Old 10-09-2002
SS454's Avatar
Dedicated Member
Yeah, I'm dumb, I read the question wrong. Sorry about that letterq.
