Old 10-04-2002
Barry Kinslow Barry Kinslow is offline
Newbie
Barry Kinslow is on a distinguished road
Digitech Vocalist Access fx unit
Hi gang.
Can anyone who's got or used a Digitech Vocalist Access tell me more about this effects unit?
Regards.
Baz.
Old 10-04-2002
wideye wideye is offline
Newbie
wideye is on a distinguished road
Cool Vocalist Access...
Are you looking to buy one? Or, do you need help with a unit you currently have?
The ACCESS is the same Digitech unit as the currently produced model called the Vocalist VR.
For info. check out:
http://www.digitech.com/products/vr.htm
If you need a .pdf version of the owner's manual, or have technical questions, check out:
http://www.digitech.com/discontinued.htm
The manual is in the center column simply called "Access".
If you have other questions, try e-mailing
support@digitech.com
E-mail is normally answered within 48 hrs.
The direct line for tech support is (801) 566-8800
8am - 5pm MST
Hope this helps.
Old 10-04-2002
Newbie
Thanks for the advice, Wideye. I have read a review of this fx unit, but did not know it had been superceded. I'll look into the Vocalist VR model I think.
Baz.
Old 10-04-2002
mikeh mikeh is offline
2.5K Gold Member
mikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond repute
wideye is correct - the Vocalist VR is in essence the same unit as the Access. It is basically a harmonizer with a built in reverb. It is designed to provide "vocal harmonies". It can provide up to 5 part harmony (high, higher, low, lower and double)
It is designed to be a MIDI controlled effect unit. Send a MIDI signal to the unit which controls the harmony. When you plug a mic into it (or a line signal) and send an analog signal into the unit, the unit provides harmony (based on the MIDI notes it receives). There are various ways to control the harmonies - useing chord patterns, useing scales or creating specific harmony notes (via a MIDI keyboard).
I use mine in the following way. I use one "track" of my sequencer (Cakewalk) to play either chords or specific notes - this performance data is then sent to the Access. I can then either plug a mic into the access (or take a line out from my mixer - which has a pre recorded "lead vocal" track). When the Access receives the "lead vocal" part, it provides whatever harmonies I've requested. The unit has a stereo out to allow panning the hamonies left and right.
There has been much debate about the "mechanical nature" of machine produced vocal hamonies. I find it best to supplement the Access harmonies with one or two real harmonies. In fact, I will often use the Access harmonies as guide vocal parts (to help stay in tune) and record real vocals "doubling" the access.
It will never replace good human voices it can be a useful studio tool. It can certainly reduce some tracking time (if you don't have to pay vocalists to multi track harmonies).
