Old 09-30-2002
sjjohnston's Avatar
sjjohnston sjjohnston is offline
Force of Nature
sjjohnston has a spectacular aura aboutsjjohnston has a spectacular aura aboutsjjohnston has a spectacular aura about
Bus Oxes
(Or should that be Oxen?)
Old 09-30-2002
powderfinger's Avatar
powderfinger powderfinger is offline
1K Silver Member
powderfinger is on a distinguished road
It looks like my post didn't get through...........I need a little help as to better understand Aux Busses....what are some techniques they are used for, how they benefit when mixing, etc.....I know that I should try to incorporate them into my mixing, but I don't know how or why.......any help would be great.
Old 09-30-2002
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Are you speaking relative to Sonar here?
In Sonar, the aux busses are typically used to apply the same FX to multiple tracks to reduce CPU consumption. For ex., if you have a mix with 3 bg vox, rather than slapping a reverb on each track, you can route them to an aux bus and use just one reverb instance on the bus for all 3 tracks.
Busses on a h/w mixer are frequently used to create submixes. For ex., you can send a drum kit to a bus and use the bus fader to raise or lower the volume of the entire kit, while still using the track faders for adjustments within the kit (louder snare, etc.).
Old 09-30-2002
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Aux's are most commonly used to send a signal out to an effects processor. Then you return that signal either thru aux/fx returns or onto their own channel so you can use EQ.
There are Pre Fader Aux's that are usually used for monitor sends in live sound reinforcement and Post Fader Aux's that are usually used for FX.
