Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 09-28-2002
Clive Hugh Clive Hugh is offline
Force of Nature
Clive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond repute
Cubasis VST Eq.
Can anyone help on this one? for some reason unknown to me I cannot Eq. on channel 1. All the others are fine, analog and midi, but I already recorded the acoustic guitar on channel 1.
I could most likely copy it to another channel but that won't fix the problem.
Clive
Old 09-28-2002
Bass Master "K"'s Avatar
Bass Master "K" Bass Master "K" is offline
Force of Nature
Bass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud of
What happens Clive? It won't let you turn the EQ on? Or it won't even let you pull up the EQ plug screen? Or it won't let you click the button's for each of the 4 EQ points?
Old 09-29-2002
Force of Nature
Bass Master,
When I left click on the channel one/two (stereo) "EQ" button nothing happens, if I left click on "insert" I can put in wunderverb, on the rest of the channels clicking on "EQ" brings up the EQ screen, I can adjust as per normal. I have version 3.7 Cubasis VST.
Clive
Old 09-29-2002
teknomike's Avatar
teknomike teknomike is offline
Oldbie
teknomike has a reputation beyond reputeteknomike has a reputation beyond reputeteknomike has a reputation beyond reputeteknomike has a reputation beyond reputeteknomike has a reputation beyond reputeteknomike has a reputation beyond reputeteknomike has a reputation beyond reputeteknomike has a reputation beyond reputeteknomike has a reputation beyond reputeteknomike has a reputation beyond reputeteknomike has a reputation beyond repute
Hey Clive,
So it doesn't even bring up the VST Channel Settings window when you click the EQ button ?
Maybe it has been moved out of your viewing area - click on the EQ button for the channel, then go to the Windows pull down menu (in Cubasis) and choose stack or cascade. See if it appears.
I've had this happen when I pulled a window out of range 'cause it was getting in my way, then couldn't find it again...
Other than that I can't find any settings that would prevent the Channel Settings window from coming up.
Cheers,
Mike
Old 09-29-2002
Joe Recorder's Avatar
Joe Recorder Joe Recorder is offline
Senior Member
Joe Recorder is infamous around these partsJoe Recorder is infamous around these partsJoe Recorder is infamous around these partsJoe Recorder is infamous around these partsJoe Recorder is infamous around these parts
Clive, I think teknomike might have a point. I've noticed this too. As I'll have several effects open when I've hit EQ I can't find it's window till I move the effects windows over or close them It seems to put the EQ window 1/2 way down or more past the task bar on mine. Very frustrating. I hope that's all it is..........Joe Recorder
Old 09-29-2002
Force of Nature
Unfortunately I don't have any better advice to add. Let us know if this works for ya. If not we may be able to dig up more....
Old 10-01-2002
Force of Nature
Guys,
Cascade, and it all appeared, like magic.
Thanks, on to the next bit.
Clive
