Track volume in Nuendo
Is there an easy and fast way to change overall volume of a track with extensive volume automation without redrawing the automation line?
To work around the problem I would insert a plugin with gain control. With all plugin processing turned off I would only use the gain control to up or down the track volume. Is there some technique allowing to achieve the same result within Nuendo itself? Thanks. |
You send the channel to a bus and use the bus fader for the overall level control. works like a charm.
*My Karma ran over my Dogma!* |
