Old 09-27-2002
tubedude's Avatar
tubedude tubedude is offline
His Majesty
tubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond repute
Cleaning scratchy pots... How?
Is there a way? Do they have to be replaced or is there some high pressure air-in-a-can that will work?
Thanks...
Peace!
Paul
Old 09-27-2002
christiaan's Avatar
christiaan christiaan is offline
1K Silver Member
christiaan has a spectacular aura aboutchristiaan has a spectacular aura about
Most pots are closed units so if any dirt would get in there in the first place, it would be hard to blow it out again.
Scratching sounds most likely come from wear and tear anyway.
I'd say replace them. I hope you're good with a soldering iron
Old 09-27-2002
Recording Engineer Recording Engineer is offline
Moderator
Recording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond repute
Cool
Unitil you get around to actually replacing them, give 'em a healthy dose of Caig Cramolin or DeOxit.
This'll help you further in that regard:
http://support.caig.com/faq.php?cat=12
Old 09-27-2002
Pier Calacino Pier Calacino is offline
Dedicated Member
Pier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond repute
Hey Tubedude,
Like Christiaan mentioned, if they have a lot of wear on them there may not be a lot you can do but change them out. Most good potentiometers are sealed, however I have been able to spray tuner cleaner down the shafts and let it soak for a while if there is no access in the body. Then you must rotate or slide them vigorously to clean the wipers and the resistor pad.
the other thing I have done is actually removed the pots from the circuit and soaked them in tuner cleaner for a while"
You may want to try cleaning them first before you replace them?
Best wishes
Pier
Old 09-28-2002
Freudian Slip's Avatar
Freudian Slip Freudian Slip is offline
Source Of Confusion
Freudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond repute
Some of the older pots I have been able to clean with TV tuner cleaner or connection Cleaner from the back. Your local GM dealership may have some goodwrench connection cleaner on hand. It has alwys been temporary though.
Be carefull if you try this. The cleaner will melt certain plastics.
Twist pots back and forth 150 times before each use That seems to work for a couple minutes.
F.S.
"If Congress can do whatever in their discretion can be done by money, and will promote the General Welfare, the Government is no longer a limited one, possessing enumerated powers, but an indefinite one"
James Madison: the father of the Constitution
