I have a Yamaha 4-track. I read here in the tutorials about using the high-speed tape speed, and turning off the DBX (I usually keep it turned off anyway). My question is, how can I get rid of tape hiss so my recordings sound better once I get them on my computer & then on CD?
Re: Get rid of tape hiss?
Turn the dbx back on. That's what it's for.
Tape hiss is random noise. There's no obvious way to eliminate it. You can EQ it out, but you'll EQ out a lot of the character of your signal too. (A small clarification to my "turn the dbx back on" solution: don't turn it on when playing back tapes recorded with it off. Turn it on when you record from now on. Unless you hit the tape absurdly hard). |
So, would I leave it on when I'm recording from my 4-track to my computer as well?
Great explanation Ed.
General wisdom is that it is better to record at most mildly (+2 db or less) into the "red", and use the DBX noise reduction like sj said. As you may know, mjr, it's always best to clean the heads before and after each recording session, along with periodically "demagging" the heads. Also, if you know in advance you're going to boost any high end EQ, do it BEFORE the signal hits the cassette unit, not after. Otherwise that will boost your hiss unnecessarily. Chris |
Just a few notes:
Tape hiss is random, even though it has a characteristic sound. The (probably wildly inobvious) point I was making is that because it's random, the precise shape of the signal isn't predictable and there's not an easy way to eliminate it by mixing it with phase-inverted "standard" tape hiss or something. Incidentally, a cassette player that runs at 30 ips would play one side of a C-60 cassette in a little under 2 minutes. Cassette decks don't even rewind at 30 ips! Quote:
Leave the geeks to their word games...
![]() dbx does a pretty fucking good job of getting rid of the hiss on a cassette tape. Of course once you're spoiled by a decent digital recording or a decent tape machine you WILL start to hear annoying hiss that you never would have noticed before. And it's also dependent on the type of program material that you're recording. Quiet acoustic stuff will accentuate hiss and loud electric rock will mask it. As to dbx: Just be sure to record WITH it ON and play back WITH it ON. Other combos won't work. Oh- and use some decent tape. And keep your heads clean. |
and to add my penny's worth...............
......................a hi-lo pass filter can also assist in the reduction of hiss. I have an old Beh'gr Intelligate that contains a Hi & Lo filter option that comes in handy on analog rec'dings.
you should record and playback with the noise reduction on! recording without it and flipping it on during playback will be horrendous!...wait, that was already said...also don't be afraid to go in the red! A hint of analog distortion is pretty cool.
1. Buy good quality tape 2. Hit the tape as hard as you can without distortion 3. Use dbx. I've later learned that this probably gives me some tape compression, which probably is why it sounded good. YMMV. My MT2X sounded awesome for being a casette porta, IMO.
Random Pavarotti Disease Victim. |
#12
The "+2 db" comment was largely based on comments by people
like Peter McIan. My understanding is that if you go into the red at +2 it comes out roughly equal to +4 once the dbx is decoded. He seemed to think the heads on a cassette multi-track were too small to hit above that dependably without risking too much distortion. Chris |
#13
Yeah! And let me also add that......
Fuck it, never mind. ![]()
.........\\|//.............. ........///|\\\............ -oOO--(_)---OOo-- -------PEACE-------- ><>eYEslIkEfIRE<>< |
#14
Since mrj is a newbie i am going to try a little more basic approach to removing the hiss..the technical debate over noise reduction schemes and the level to record at might be doing more harm that good (depending on mrj's experience with those sorts of things, of course). The best suggestion so far was the first..of course..don't record to tape in the first place
. What you might want to do is use your 4 track as simply a mixer and run it straight into your computer, provided you have a program on your computer that will be able to edit 4 tracks or so. I have heard on this board people talking about a couple free multitrack recorders which certainly aren't be the best, but worth a try. if you DO have a recording program then once you record it in just touch it up with a lil noise reduction and go on to the next track. if you don't have a recording program already and the free one doesn't offer decent noise reduction then I have only wasted your time ![]() have a nice day! dlv |
#15
#16
Have any of you guys done the "emphasis/de-emphasis" thing?
You know where you boost the high end EQ going into analog tape, then reduce the high end EQ by the same amount when you mix down. That has the effect of reducing hiss even without DBX. (although using dbx in addition is better) Chris |
#17
steinberg denoiser works well.
The Lands End Road Project... |
