Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 09-23-2002
ZEKE SAYER's Avatar
ZEKE SAYER ZEKE SAYER is offline
Being a virgin sucks
ZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond repute
Question is there any way to mic a kick with 2 mics and have them "in" phase?
i've been looking into this mic placement. you put one mic on the inside, upclose to the beater, and then one outside the kick pointing at the hole. how can you do this without phase cannceling?
thanks,
zeke
Old 09-23-2002
Gidge's Avatar
Gidge Gidge is offline
Lapdance Test Dummy
Gidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond repute
Cool
experiment and move them around.....
one way is to move them around until you find where they are MOST out of phase, and then pop the phase on one.......
Old 09-23-2002
Track Rat's Avatar
Total Gear Slut
Zeke, just because you use two mics doesn't mean you're going to have a phase problem. In the situation you described the two signals wouldn't be too far apart in phase. If you're working in a DAW you can look at the two wave forms and copare their phase. If you're not using a DAW you still have your ears. If there's a phase proble, you'll hear it. If when you have both mics solo'd it'll have weak bass or a strange hollow sound. When you mute one of the mics, the bass response will improve. Now if you're mic'ing a kick with a mic inside and one on the beater side there's a good chance you could run into a phase problem. You see, when the beater strikes the drum head, the initial pulse will cause a positive excursion on the inside mic and can cause a negative excursion on the outside mic by the beater. In a case like this the two signals when summed to mono would be 180 degrees out of phase. Again, use your ears if you don't have a DAW to see if you have a problem. You can either flip the phase of the offending mic, start moving the mic around or in a DAW, slide the track around to line the phases up.
Mike
Old 09-23-2002
ZEKE SAYER's Avatar
Cool
yeah,
i'm using a daw. (fostex vf-16) but when i look at the wave form, what a'm i supposed to look for? and i don't have a pre-amp for my kick so i don't have anyway to switch the phase. i'm saving for one though. i think i will use it on other things besides the drums. do drums really did a pre?
Old 09-23-2002
PapillonIrl's Avatar
PapillonIrl PapillonIrl is offline
Medicated Member
PapillonIrl is on a distinguished road
You have to zoom RIGHT in on the two waveforms and see if the curves line up together, I'm not sure if you can do that on your machine.
pAp
Old 09-23-2002
rocky outcrop's Avatar
rocky outcrop rocky outcrop is offline
Senior Member
rocky outcrop is on a distinguished road
move them and listen I have miced this way heaps and havnt had much trouble with phase.
Old 09-25-2002
fenix fenix is offline
1K Silver Member
fenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond repute
Originally posted by ZEKE SAYER
yeah,
you want to flip the phase of the mic that is on the beater.
Even though you do not have a preamp that will flip phase, you can still accomplish flipping the phase by taking a short mic cable, cut it open and reverse 2 of the wires (pins 1 and 2) and hook that mic cable up to the mic cable that has the mic that you want to phase flip.
Old 09-25-2002
cordura21's Avatar
cordura21 cordura21 is offline
370HSSV- 0773H
cordura21 is on a distinguished road
fenix is correct. And don't forget to mark it red, so you know that that cable flips polarity.
"A woman in a bicycle, with a straw hat, is the most flagrant violation of the laws of aerodynamics." (Dr. Vaporeso)
Old 10-03-2002
ZEKE SAYER's Avatar
Question
how can i "cut" the cable open without destroying it?
Old 10-08-2002
ebeam ebeam is offline
Dedicated Member
ebeam is on a distinguished road
Actually, fenix is not correct - but I think he just misread your question. If you have both mics on the same side of the back head (the one the beater hits) you don't need to invert the polarity. The only reason you'd want to do this is if you have one mic on either side of the head. Listen to Track Rat, experiment with sliding tracks around in your DAW (or put a delay on the close mic if you can't do this) and mic position until you get something that sounds right.
Old 10-08-2002
Track Rat's Avatar
Total Gear Slut
If you need to make a phase reversing cable, you just reverse the wires on pins 2 and 3 (1 is shield) on one end only. Be sure and mark this cable well so it isn't mixed with normal ones.
Mike
