Ground Question
I'm having a problem in my home studio with what I'm assuming is a Ground issue....when I plug in a bass or guitar to any amp, the amp buzzes like crazy the second the player takes his hands off of the strings, no matter which position the "ground lift" switch on the amp is set to. However, when I take the same guitar/bass and amp to another location, this buzzing is not an issue. BTW, this affects only the amplifiers in the room, and has not (as yet, anyway) affected the recording gear.
Does anybody have any ideas about what I might be dealing with here, and what the possible solutions to try might be? Thanks, Chris
Wherever you go, there you are. www.chrisfitzgeraldmusic.com |
Try switching off your monitor...
CRT monitors (STandard big ones ) actually emit a magnetic field which induces an electric signal in single coil guitar pickups (especially cheap strats )Normally, before I hit the record button, I try to switch off the monitors, just to clean the sound a bit. Sometimes it works, sometimes it doesnt. Try doing a search here, there must be athread where it's been discussed. cheers R
I'm no gear slut, I'm just the worlds best salesman... I can sell anything to myself. |
Try this thread, and look for knightfly's reply...
he's already written what I couldn't be bothered with writing ![]() http://homerecording.com/bbs/showthr...guitar+monitor
Rochey,
Thanks, but I don't think that's the problem...I use an LCD monitor with my G4, and the hum persists even when I'm not recording and the computer itself is turned off. My wife has a 19" CRT monitor in the next room, but I doubt that could be causing the problem. Or could it? I should mention that my studio is in a very old house, although the wiring was redone sometime in the 70's. Are there any tests I might be able to run to check the ground on that circuit? Or any products out there designed to "clean" power that seems "dirty"?
Re: Ground Question
have you tried another circuit in this house? the outlets are two prong or three? do you have an outlet tester? if not, go to Home Depot or Lowes and buy one or borrow one if available. is this room above ground or a basement with a concrete floor? |
CRTs, TVs (even in other rooms), dimmer switchs (especially in a halogen floor lamp we have here in the house) are all notorious noise makers. If i'm downstairs in the studio and my girlfriend turns on the floor lamp in question upstairs in our bedroom my Strat or Tele lights up like a pinball machine, and my studio is on a dedicated circuit with its own subpanel/breakers.
Also how and where things are plugged in to power and audio gear, it's easy to set up a ground loop. For example, say you have a bass amp on one side of the room and it's plugged into the wall outlet nearest to it. Your recording gear is on the other side of the room and gets its AC from a different source. If you were to take a direct out from the bass amp to your recorder now you're set up for a ground loop.
Mike |
that's good food for thought... Track Rat
does moving around in the room make significant differences in Buzzing? |
Re: Re: Ground Question
It's on the first floor, with a wood floor and some area rugs. Thanks for the suggestions, I'll try some of those out!
if all you're doing is connecting directly into the amp from the Guitar and the amp is only connected to power, then you won't have a ground loop. if you're using a Direct Out into the Board or something like that, then you may have a ground loop, especially if the board and amp are on different circuits. if this is the case, then you'll need to use a DI Box or use power from the same outlet (best) or another outlet but same circuit.
does moving around make a difference? what kind of pickups... single coil... humbucker... tried other guitars... how about fluorescent lighting |
#12
Open every breaker in the box except this rooms outlets. what then.
if still buzzing, try another circuit in the house and do the same. do you live under or near a power transmission line? is the problem worse at certain times of the day? |
#13
How many pieces of gear in your studio have "wall warts" or "line lumps" for power transformers? Now, are there any audio lines that run within 3-4 feet of any of those transformers? If so, try either moving wires away from the transformers or unplugging any unnecessary transformers.
I once made the mistake of plugging a wall wart into the auxiliary AC outlet in the rear of a power amp, past which the two 24" shielded phone cables ran to the power amp input. If the resultant hum had been any worse, I would have thought I'd plugged the speaker directly into the AC outlet... Ever since then, I've made sure to banish ALL transformers to their own little world, as far away from all the other "children" as their cords will allow. Basically, you need to turn off EVERYTHING in your studio, try the amp/guitar(s) in question, and if no hum, turn on one thing. Repeat the tests until you turn on something and it hums. BTW, we ARE talking about 60 hZ, are we not? sounds real close to the second lowest C on a piano. I know this sounds like a silly question, but people have called all sorts of noises "hum", just checking - Did the people who built these "boutique" instruments know about shielding/grounding? Are the control cavities lined with copper foil, and are all the pots connected together at the cases, with a common wire? Most anything else that I could think of has already been mentioned. The outlet tester mentioned runs about $10-$15 at home centers - it comes with directions, you plug it in and certain lights will light up - the directions tell you what's wrong in each case. That's the first thing I plug in when setting up for a gig - you wouldn't believe the bizarre stuff club owners think passes for power... Steve
Hey, I thought this was gonna be EASY!??! |
#14
