Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 09-15-2002
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Vocals Are In Another Room
I've got a mix I'm working on. Everything is coming together nicely, but the vocals sound somewhat like they are in a different room than the music track. The music is fine and the vocals are fine, they're just in different places.
So my question is, what tool(s) should I be using to bring everything together - eq, reverb, something else??
TIA
Old 09-15-2002
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
No clue.
Can I come over and hear it?
Peace
Old 09-17-2002
littledog's Avatar
littledog littledog is offline
Three Thousand and Counting
littledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond repute
Use a unifying room program (reverb) on all the tracks, rather than having a completely different reverb on each.
Old 09-17-2002
dachay2tnr's Avatar
One Hit Wonder
Thanks, LD. Just so I understand, are you saying to dump any reverb on the individual tracks, and just use a single reverb on the master out? Or to use a single (unifying) reverb on the master in addition to any track reverbs? And how would I account for certain tracks requiring more reverb than others?
BTW, I suspect the problem stems from the fact that the vocals and some of the instruments were recorded in one place, while other instruments were recorded in another, and then, in addition, some DXi synth instruments were also added.
Old 09-17-2002
MISTERQCUE's Avatar
MISTERQCUE MISTERQCUE is offline
Not Just Anutha Brutha
MISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond repute
Myself, I prefer to record my original tracks dry and then include var 'Verb's during mixdown!
Old 09-17-2002
littledog's Avatar
Your method is certainly valid, Mr.Q, but you aren't suffering from the problem dachay is having, so unification isn't an issue for you. I was assuming he was recording dry as well, except for the differing natural ambiences of the different rooms. The only truly "dry" recording would have to be done in an anechoic chamber, which it turns out, whenever it's been tried, results in about the most God-awful recordings one could possibly imagine.
Dachay, while adding reverb to the whole mix might work if you're lucky, you still might prefer to have the control of differing amounts (or none at all) on certain tracks.
The way to do this is to use an aux send (or a stereo pair of aux sends) on each track to send varying amounts (or none) of each track to one reverb program (let's say a small room). This will be the unifying element in the mix.
Once you have that, there is no reason you can't add other reverbs (like a plate, for instance) to certain tracks, maybe to get a nice long tail on your snare drum for instance.
Good luck.
Old 09-17-2002
dachay2tnr's Avatar
One Hit Wonder
Exactly correct, LD. What makes it worse is that neither room has any acoustic treatment, so the room ambience is very prevalent.
Thanks for your help, I'll give your suggestions a try.
Old 09-18-2002
volltreffer's Avatar
volltreffer volltreffer is offline
Imply depressed
volltreffer is on a distinguished road
High !
The only thing that I could imagine is to give the tracks some more verbs from one or two kinds. Just use different send volumes so you can have different verb volume.
As a first try, I'd use some early reflection program only, as these give a 'room colour' which might help 'welding' everything together. In a second step, you might try to add a second verb with a longer tail...
Hope this helps....
aXel
Hey - just noticed this was my 100th post - so I'll send a virtual cheers out to you all
