Organ Sync - PLz help
Hello all
i have Creative Audigy platinum and korg Tritton i want to make a sync between the organ and the computer using cakewalk pro audio 9.03 what is the steps needed to make this ? and plz someone tell in case that i want to record the tracks from the organ as MIDI or if i want to record it to wave . Sorry for my bad English ![]() Any help will be appreciated |
You have two choices here, to record the output of your keyboard as a MIDI sequence, or to record the actual audio data produced by your keyboard.
MIDI - keyboard connected to sound card with MIDI cable. === - Set a track up in Sonar to be recording from whichever MIDI channel the Korg is sending. - IN will be the SB MIDI port - Arm the track and record. - Repeat process for additional tracks (you will need to use unique MIDI channels for each track, otherwise you will lose your sound settings. RESULT = a bunch of MIDI tracks AUDIO - keyboard connected to the sound card's line in with a normal audio cable - Set a track in Sonar to record from your audio line in - IN will be the SB AUDIO port - Arm track and record - Repeat process, (remembering to dis-ARM any previously recorded tracks) RESULT = a bunch of AUDIO tracks Now the question for you is - which method is more appropriate for what you are working on? Personally I try to keep my tracks in the MIDI domain as long as I can as this allows me to change my mind about the sound patch being used, and allows me to come back and edit something if I decide I don't like it! Hope this helps, Q.
<insert something witty here> |
