Help!!! Sonor 2 XL keeps crashing!
For the first week, the program worked fine, then it started crashing almost everytime i turn it on. It freezes up the whole computer. Is there anything i can do to keep this from happening?
thanks |
Is it just this app or does it happen with every audioprogram you have? Is your soundcard working properly?
Two wrongs don't make a right, but two Wrights once made an airplane... |
Most cakewalk problems are due to incompatibility with the version of windows you might be using.
If this is the message you get before it crashes, 'An application error has occurred and an application error log is being generated.' Here's what you can (should) do: 1. search for drwtsn32.log 2. See if it did generate this file and search the file to see if it shows the sonar executable as the cause of crash. 3. If yes, there're several ways of debugging this problem and fixing it. The problem is because sonar made a request for memory with the MEM_TOP_DOWN flag set. A bad pointer was returned, causing the Dr. Watson error message. (You really don't need to understand this sentence) Easiest thing to do to fix this is, get the latest service pack of the windows version you're using (if you're using win2000, get serive pack 3.0) and your problem should be gone. |
Also - try holding the SHIFT key down when opening your project. Starts it in safe mode and you can choose which plug-ins to load. It may be that it is one particular plug-in that is killing you. If so reload the plug-in, (or see if it has a patch), and try again.
<insert something witty here> |
win2ksp3 no fix the problem buddy! still crashing. same error.
I tried that shift thing and it must be just in sonar 2.0? |
