Old 06-06-2000
dabluesman's Avatar
dabluesman dabluesman is offline
Dedicated Member
dabluesman is on a distinguished road
Question
I've had my RP-10 for several years and I noticed that the last time I switched it to stereo mode and used the headphone jack that I only got sound through one speaker. The strange thing is that if I stand the RP-10 up (lean it against the wall or something) with the jacks pointing upward I get sound out of both speakers in stereo. Anyone have any idea what is going on here, do I have a loose connection somewhere internally or something?
Old 06-07-2000
MISTERQCUE's Avatar
MISTERQCUE MISTERQCUE is offline
Not Just Anutha Brutha
MISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond repute
Wink
It does sound like you have a loose connection in your equipment. A similar problem like that happened to me on 1 of my amps and upon removing the cover i noticed that the wire connecting to the left channel
outputs were gnarled off,(prob. a mouse).
Fortunately i had the schematics and traced the left channel and soldered a new connection to the left audio posts.My advice is to take it in for repair as this is more
ideal.
Old 06-08-2000
Track Rat's Avatar
Total Gear Slut
Wink
Does it only happen when you use your headphone jack?
Old 06-08-2000
dabluesman's Avatar
Dedicated Member
Wink
Yes, only when it's laying flat on the floor. If I tilt it up (past a certain degree) it will work fine. The left and right/mono jacks are fine.
Old 06-08-2000
Track Rat's Avatar
Total Gear Slut
Wink
More than likely you just need the headphone jack replaced. It's probably a closed frame type where it's normaled thru when there's not a plug in it. If it's out of warrenty crack it open and look around.
