Old 08-03-2002
Abbott Abbott is offline
Senior Member
Abbott is on a distinguished road
Bouncing Drum Tracks
I was thinking about getting a Tascam 788 digital recorder. Would this work=
track 1 - SD
track 2 - BD
track 3 +4 - overheads, L and R
all this bounced in stereo to stereo track 7/8 on the tascam. Would this work and would it sound just as good as when they were three seperate tracks? Thanks a bunch.
Old 08-03-2002
BrettB's Avatar
BrettB BrettB is offline
1K Silver Member
BrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond repute
Bouncing may digitally not give any loss of sound quality, it gives you less abilities to add some extra EQ or compression afterwards, and is little versatile off course.
Just one question about your setup: don't you use your toms? If you really want to use them, you need to mike them... The signal that goes into the overheads aren't likely going to give you the punch you want in your toms.
www.protoolsforum.com
The board for all Pro Tools (LE) users!! Finally back online.
Old 08-03-2002
Gidge's Avatar
Gidge Gidge is offline
Lapdance Test Dummy
Gidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond repute
Cool
bouncing is a necessary evil.....it can work though.....if you have the capability, id suggest backing up the 4 original drum tracks in case the bounced mix doesnt work well with the song.....
a 4 mic setup(or less) is very common in home recording, and if done correctly, WILL pick up the toms just fine.......
