Hi, I'm having problems trying to figure out what to do with my listening environment around here... At the moment, I have my sound card out to a Altronics Preamp, and a home made 50 watt amp, my speakers are Jamo Power 566's (500watts each), the preamps tracks have been worn out, cause its like very old, and the quality is horrible, the amp is almost dead as well, and I need to buy new gear. I can't decide between these options.
1. Buy a Yamaha (60watt amp). Sell existing Preamp/Amp About $400 2. Buy a Jands J600s (350watt amp Second hand) then Sell existing Amp and Fix existing Preamp. About $600 3. Buy a Jands J600s (350watt amp Second hand) then Sell existing Amp and buy a mixer / amp of some kind. About $800 I have looked at other alternatives... but so far these are the only ones that are within a decent budget for me at the moment. |
I don't understand... why do you have a preamp in between your soundcard and the amp?
I've never heard of Jand..... but some common studio amps are Hafler (P-Series), Crown, Bryston, and QSC... Forget the Yamaha amp... the ones I mentioned are far better..........
bruce valeriani recording articles http://www.bluebearsound.com/images/bb_siglogo.jpg |
SoMm |
Say WHAT??????
By it's very defintion, an amplifier takes either a line-level signal as input, and amplifies that signal with enough level to drive speakers/monitors attached to that amplifier as outputs....... There is absolutely no need for a preamp in this situation..............
I have an older SAE "preamp" I've used for a routing amp - it was originally designed to be part of a high end stereo with separate power amp(s) - it's probably called a preamp because of the phono inputs, but it's really more of a "router/tone control" - it has 3 band EQ with a defeat switch, inputs for 3 tape decks, 2 phonos, 2-3 aux's, some filters, mute switch, etc - When using this for anything other than phono inputs, it doesn't really "amplify", but nonetheless that's what the nameplate says it is...
Maybe this is similar to what mister is talking about??!?
Hey, I thought this was gonna be EASY!??! |
Perzackly... :=)
