cd burner won't burn my audio files
ok,here i go again. i got a new hard-drive and my adaptec ver 4 with my 12x burner is not burning my cd's.i have 13 songs on my album i sell at my shows. i generally copy the songs out of the C: folder where i have them when i open up Adaptec.
ok,i have wav files in my folder. usually it will read and burn right after but right now it only reads them and then i get a coaster. it worked fine on my old hard-drive. any suggestions? here's my specs: Windows 2000 Pro AMD 1.2 ghz Abit KT7A-Raid mobo Chipset-Via Apollo KT133A 300 watt P/S 256megs SDRAM PC133 Maxtor 80 gig drive Geforce4 4200 Ti 128 megDDR vid card GlobalWinCAK38- HS/Fan MS wireless/optical Intellimouse Linkysys 10/100 PCI adapter Telocity DSL gateway Creative 56k Modem Blaster Audiophile2496 Soundcard Buslink CDRW 12x8x32 19”Orion moniter lizard thx again |
Couple of possibilities- (I've just been through this myself)
Bad media. Other apps that you think aren't running but ARE and interfere with the burn process. I've burned dozens of CDs successfully while doing a lot of other stuff (since I went to a P4) but I learned the hard way that it isn't just the available power on the system but the behavior (or misbehavior) of those other apps that dictate whether you'll get a coaster or not. |
Clean the optics. If the burner's been in active duty for a long time, it's probably time to clean out its eyes now. Use one of the commercial CD cleaners, or if you're adventurous like me, open up the drive and do it manually.
Sang |
thanks yall, yup i can drag wav files onto the cd but they remain wav files. i also can drag mp3's over to. i can also copy my data files to it also.
but for some reason when i go to copy all 13 songs in a sequence to burn a cd,i get what i said above.hmmmmm,they are not changing into cda files. i kinda thought adaptec converted them as it burned.am i wrong? |
..just a possibility |
Yeah Adaptec should convert them if you've selected 'Music CD' in the beginning. If you've done 'Data CD' then the .wav files will remain .wav files.
Sang |
