Old 07-22-2002
dassy dassy is offline
Senior Member
dassy is on a distinguished road
best "value" monitors for $300-$500
im looking for monitors that i can make VERY accurate recordings on but im on a budget, on the other hand i dont want to have to upgrade them for sum odd years, so i wanna spend the extra $$$ if needed so i can get the best value.
thanx ahead of time
Old 07-22-2002
Guernica's Avatar
Guernica Guernica is offline
breastfed
Location: In a world full of chimpanzees I was a monkey
Guernica has a reputation beyond reputeGuernica has a reputation beyond reputeGuernica has a reputation beyond reputeGuernica has a reputation beyond reputeGuernica has a reputation beyond reputeGuernica has a reputation beyond reputeGuernica has a reputation beyond reputeGuernica has a reputation beyond reputeGuernica has a reputation beyond reputeGuernica has a reputation beyond reputeGuernica has a reputation beyond repute
.........very happy w/ my Tannoy Reveals........under 4 bones too.
............good luck.
Old 07-22-2002
Gidge's Avatar
Gidge Gidge is offline
Lapdance Test Dummy
Gidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond repute
Cool
JBL LRS25P
Old 07-23-2002
Kevzmusic's Avatar
Kevzmusic Kevzmusic is offline
Dedicated Member
Kevzmusic is on a distinguished road
Thumbs up
Yorkville YSM-1P's
KEV
Old 07-29-2002
djc's Avatar
djc djc is online now
I am NOT insane.
djc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond reputedjc has a reputation beyond repute
Yorkville YSM-1P's
Don
Old 07-29-2002
keilson's Avatar
keilson keilson is offline
Force of Nature
keilson is on a distinguished road
I have event 20/20 passive. I use an Alesis reference amp....works well for me.
Old 07-29-2002
Smokepole Smokepole is offline
Dedicated Member
Smokepole is on a distinguished road
I have a good stereo to use for power so I just bought the YSM1. $86 each. If you are going to use them near a computer monitor you can get the shielded ones YSM1i about$99 each.
They are so cheap but I really liked them so I ended up getting a second set because I'm recording in two places. At that price it wasn't worth transporting them around.
Old 07-30-2002
ambi ambi is offline
1K Silver Member
ambi is on a distinguished road
yea
yea, ysmip's are the way to go i say. No, i say go audition all of the monitors in your budget and then decide yourself. But the ysmips are good, made in canada
The Lands End Road Project...
Old 07-30-2002
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
Take a listen to the KRK Rockits - very accurate in this price range, with particularly good imaging.
Cheers, RD
Old 08-02-2002
doulos doulos is offline
Dedicated Member
doulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond repute
behringer truths almost as flat as the hr8242 best way to traslate any mix to any speakeer system 400 dollars
Old 08-02-2002
JuSumPilgrim JuSumPilgrim is offline
Force of Nature
JuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond repute
Exclamation B2301 review
I just spent a week with the behringer's and they are NOT almost as flat as the mackies. They have a noticable peak around 3k which can be problematic bec its pretty narrow though probably not more than 2-3dB. Theyre also exaggerated on bottom without much detail. But you can tell if your mix has bottom and what type...deep bass, midbass, boomy bass, etc. Theyre exaggerated on top but if you set the treble to -2 or -4dB theyre ok.
If mackie's imaging is a 10 then behringer's imaging is a 3.8 (most other monitors in this range have much better imaging..event, tannoy, krk, hafler, yorkville). The midrange is pretty linear except for that 3k bump although overall the mid detail isnt that hot. If mackies tansient response is a 10 then behringer is a 4. If you listen to both speakers back to back youll likely say...there aint $900 worth of difference. On that count you would be right if you were going to use them in your living room. But if you take them home and put them to the test, play back your first couple of mixes (the shitty ones with no imaging or definition) and see which ones are more forgiving which monitors show flaws, the answer is mackie by a mile---nay, by a hundred miles. The TRUTH here is that they shouldnt be compared bec they are in a very dif price range but I guess anytime behringer puts out a product "inspired" by mackie their products will be compared. For $400 its a good deal. The one caveat here is though the behringer's ARE forgiving and hide flaws, they are easier to learn and more predictable than events, tannoys, and krks bec of their mostly straightforward midrange. I would not use these as a main reference as just about everything on them sounds better than it should but as a 2nd or 3rd reference theyre not bad.
  #12
Old 08-02-2002
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Re: best "value" monitors for $300-$500
A truer oxymoron has never been spoken here......!
I want the most accurate monitors -- but I don't want to pay what it actually costs to get that!
Yeah, friend... me too!!!
  #13
Old 08-02-2002
Kevzmusic's Avatar
Dedicated Member
Yeah :-)
Just like the rest of us....we want the best gear for little or NO money.....hhhhmmm, not in this life mate!
Well, If you buy the Yorkville YSM-1P's.....which only cost approx $430 USD online.....you will have a very decent set of monitors for a budget price.......
KEV
  #14
Old 08-02-2002
Rubo4's Avatar
Rubo4 Rubo4 is offline
Senior Member
Rubo4 is on a distinguished road
JBL LSR25P - as mentioned before.
