Need all the links, advice, software , instruction etc. I can get to learn to do this.....at least on the sites that don't digitally block.
Just AUDIO!! Thanks all in advance. Graham
onegram |
You don't necessarily need any extra software. Your soundcard's mixer should have an option on the Record level slider to "record all" or something similar ("All" on some Sound Blaster types). Then any sound being made by/going through your 'pooter should get recorded. You also may want to mute any sound sources you don't want to record, like the CD player, the synth, etc. (so you don't get extra noise or Windows beeps and the like). Just have the Volume, Wave, and Record sliders un-muted. Hit record in the software of your choice, and start the playback.
Even if the site won't let you digitally copy/download the file, or blocks it in other ways, this should work (as far as I know). As far as I know, if it plays through the speakers, this method should capture it. Could be wrong, I haven't done this very often. This method can also be used to record the audio your 'pooter plays when playing a MIDI file. |
Yup. I've done it this way a bunch of times. You have to be careful of volume levels though. You'll have to set your volume levels just as you would if you were recording from an external source - you can still clip, you can still get a weak signal.
If you can, use a recording program that allows you to monitor your levels while recording, and keep that puppy around -3db. |
"A woman in a bicycle, with a straw hat, is the most flagrant violation of the laws of aerodynamics." (Dr. Vaporeso) |
Great link, cordura21
