Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 07-17-2002
mikemoritz mikemoritz is offline
Senior Member
mikemoritz is on a distinguished road
Mixing the Snare
On the latest tune I'm mixing, I'm having trouble with the snare coming through the really distorted sections. Should I remix and do everything around the snare? Or should I maybe try and get the snare a little more even? Any suggestions? It's like, there, but it sounds kind of like it's in the background. If I push it any louder, then the peaks start to clip the mix.
Mike
Old 07-17-2002
Seanmorse79's Avatar
Seanmorse79 Seanmorse79 is offline
Ghetto Flabulous
Seanmorse79 has a reputation beyond reputeSeanmorse79 has a reputation beyond reputeSeanmorse79 has a reputation beyond reputeSeanmorse79 has a reputation beyond reputeSeanmorse79 has a reputation beyond reputeSeanmorse79 has a reputation beyond reputeSeanmorse79 has a reputation beyond reputeSeanmorse79 has a reputation beyond reputeSeanmorse79 has a reputation beyond reputeSeanmorse79 has a reputation beyond reputeSeanmorse79 has a reputation beyond repute
I'd try to find the frequency the snare "lives" at (by sweeping the eq the ol' fashioned way) and cut it the same frequency (narrow) from the guitars. This will help give the snare a little breathing room in the mix.
Old 07-17-2002
PowerCouple's Avatar
PowerCouple PowerCouple is offline
Guitar-Noise Megafreak
PowerCouple is on a distinguished road
Compression, my friend
Try a little compression on the snare, so you'll get it even.
That's the way to do it, but if the drummer played it even, then it should sound that way! Unless you are putting too much guitar on it...try to keep it "real" unless that is not what you want.
For the peak issue, compression will help also. Try a VERY smooth limiter...
Peace...
PC
Peace.
PC
Old 07-17-2002
jmorris's Avatar
jmorris jmorris is offline
livebandrecordings.com
jmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond repute
I agree with Powercouple totally. Add some compression to the snare. I go to tape with compression on the snare.Tends to give it more punch. Also tunning is so very much the key. Ive had drummers with crappy recording snare..period. I since bought an old Ludwig Acrilite snare at my drummer advise. I let him pick it out. Now if there is a snare question, Ive got one that I know will record well. I tune the head down a little for a fatter sound, tighter for snappier.
Old 07-17-2002
BUT...
...also be careful if you are going to tweak EQ on the snare, because some lo cut will be ok, but if you go on too much will make it sound like a sleeper hitting a wooden table. (Happened to me on my first recording)
Also be sure that it is on phase with the snare sound coming from other sources (overheads mics, Bass drum mic...etc), because if you do noy have it in phase it will sound thin and indinstinct. Phase it up with the others and it will really fatten up!
Peace...
PC
Peace.
PC
Old 07-18-2002
Igormeister Igormeister is offline
Senior Member
Igormeister has a reputation beyond reputeIgormeister has a reputation beyond reputeIgormeister has a reputation beyond reputeIgormeister has a reputation beyond reputeIgormeister has a reputation beyond reputeIgormeister has a reputation beyond reputeIgormeister has a reputation beyond reputeIgormeister has a reputation beyond reputeIgormeister has a reputation beyond reputeIgormeister has a reputation beyond reputeIgormeister has a reputation beyond repute
Add nice short room reverb on snare in that distorted part.
Under 1 sec decay, and use first reflections - if possible use only first reflections combined with predelay ( 5-30 ms ).
It sounds bit unnatural soloed, but really enhance snare in loud mix.
Igor
Old 07-18-2002
Senior Member
I think it could very well be a phasing issue, but how would I go about "phasing it up" with the other mics? Other than that, thanks for the suggestions.
Mike
Old 07-18-2002
Track Rat's Avatar
Total Gear Slut
It doesn't sound like a phase issue by the way you describe it (it only gets weak during a busy part). It sounds like it's fighting for room in the frequency spectrum with other sources. If it's a phase issue, it would sound thin and strange all the time. If you're working in a DAW you can examine the drum tracks in a wave editor and compare their phase relationships.
Mike
Old 07-18-2002
100 % agree with Track Rat
I am just trying to see all the possibilities.
It happened to me once, a snare out of phase disappeared in the "heavy" parts. But that was because being "off-phase" made it lose frequencies (they were being canceled) and in the soft part you could not notice it because it had room for "breathing" in between the other instrument's freqs...
Peace...
PC
Peace.
PC
Old 07-18-2002
UberGawkman UberGawkman is offline
Senior Member
UberGawkman is on a distinguished road
I totally agree with notching the guitars where the snare sounds good.
Old 07-18-2002
Yes, yes, it's true but...
..I also agree with the cutting possibility, but bear in mind that guitars and snare share A LOT of frequencies... so if you cut some guitar to make the Snare more prominent, the guitar will lack some part of its sound spectrum...and that is not good either.
It's a difficult issue, just play around with all the possibilities you have. Tweak around a bit to see what happens (keep always an undo possibility).
Peace...
PC
Peace.
PC
