Is it just me or has anyone else run into this. I am running this EQ as a insert on my vocal channel. I am running out of my mackie vlz sr-24-4, I have the input and output set at +4 on the EQ, and when I solo the vocal channel on the board I am well below clipping. Yet this eq seems to want to clip.
Is it this EQ? If I pull the gain enough to stop the clipping it is hard to get much signal? Thanks F.S.
"If Congress can do whatever in their discretion can be done by money, and will promote the General Welfare, the Government is no longer a limited one, possessing enumerated powers, but an indefinite one" James Madison: the father of the Constitution |
I think I need to unplug the insert cable. Then set my gain using the solo function. Then plug in the eq and adjust it.
I think I may be seeing the return gain from the insert. That would explain the clipping on the eq with the solo meter below zero. I will try this in the morning ![]() F.S.
