Old 07-07-2002
ANCH ANCH is offline
Newbie
ANCH is on a distinguished road
Soundcraft Ghost 8 bus - Mackie 8 bus - choice problem
Hi? I need for mixing console & don't know what -Soundcraft Ghost 8 bus or Mackie 8 bus.
Tell me please what are you think about it.
Old 07-07-2002
knightfly's Avatar
knightfly knightfly is offline
GrouchyOldFartOnBatteries
knightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond repute
I've used the Mackie and was only half-impressed - have NOT used the Ghost, but every BBS I frequent the vote would be about 6-1 in favor of the Ghost as near as I can tell. I hope half an answer is better than none... Steve
Hey, I thought this was gonna be EASY!??!
Old 07-07-2002
Markd102's Avatar
Markd102 Markd102 is offline
Wannabe Gear Slut
Location: Australia. Almost as far south (mainland) as you can get
Markd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond repute
No contest.
GHOST!
Brain Under Construction
Old 07-08-2002
goran goran is offline
Newbie
goran is on a distinguished road
i'm working with MACKIE 24/8bus and had opportunity to work with GHOST, and i have to say that GHOST is better choice (for live performance) , cause it has more aux outputs wich is really great when you don't have monitor mix pult. For example, i use four separate monitor lines, and Mackie has only 4 aux outputs that can use in the same time, but i use aux for reverb to, and then have to use tips and tricks with MIX B. So, for Live GHOST is better choice..
For studio, MACKIE is great, and cheaper, and I realy enjoy to work with them
Old 07-08-2002
ausrock's Avatar
ausrock ausrock is offline
Feeling Monolithic
ausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond repute
Definitely the Ghost.
Another option, if you are willing to consider second hand gear is the Soundcraft Spirit Studio...............24 channel (I believe there is a 32 channel as well), 8 buss, in line console which was the forerunner to the Ghost.
The Mackie 8 buss consoles were designed with some compromises to allow them to be both a "live" and "studio" console. Soundcraft put out two different consoles...........the Studio 8 buss and the Live 4 buss, each one being having features more suited to a specific application.
The fact that Soundcraft pre's and EQ's are somewhat "nicer" than the Mackies doesn't go astray either.
Old 07-08-2002
Track Rat's Avatar
Total Gear Slut
I like Mackies just fine but the Ghost is the better of the two. The pre's are fairly simaler but that's where the simalarities end.
Mike
Old 07-14-2002
mastahnke's Avatar
mastahnke mastahnke is offline
Linux Man...
mastahnke is on a distinguished road
Ghost!
I have used both a little. The pres on the SC are nicer. Plus, the board is layed out a little better in my opinion. (And you get to spell analog with a 'u' ANALOGUE)
--MIKE
Old 07-16-2002
PhilMckracken PhilMckracken is offline
Senior Member
PhilMckracken is on a distinguished road
Have Mackie
I have the Mackie 24-8 and it is not bad at all. Very felxible, sounds good etc. My main complaint however is the EQ. Don't really like the sound of the EQ and though I have not used the GHOST, I have heard that the EQ on the Ghost is superior. I can believe it and, if I had it to do again (actaully, I might or could if'n I really wanted to) I would probably choose the Ghost budget permitting.
