Old 06-24-2002
synergy's Avatar
synergy synergy is offline
Senior Member
synergy is on a distinguished road
making drums imperfect
I have been using Fruity Loops 3 for a fairly long time now. I have always been happy with it, except for the fact that I couldn't link it directly with Sonar, like a dxi synth. I have Battery, and I just found out how to use it, but I really miss the "shift" function in Fruity. Is there any way to imperfecticate up the drums with Battery?
Old 06-25-2002
Lord Wan Lord Wan is offline
Newbie
Lord Wan is on a distinguished road
Wink
Play it by hand !
...Or try the quantize effect in Cakewalk :
- select the midi track
- right-click / MIDI Effect / Cakewalk Fx / Quantize
- in the dialog, enable the randomize check box and set the amount of shift.
Old 06-25-2002
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
Groove-Quantise is also great!
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 06-25-2002
synergy's Avatar
Senior Member
thanks guys, that helps a lot, but I guess there is no way to get precise shifting like in Fruity using Battery and Sonar?
Old 06-25-2002
moskus's Avatar
I really don't understand what the "shift"-function in FruityLoops do. Please explain!
Old 06-25-2002
synergy's Avatar
Senior Member
In FL, you can individually edit notes so that they play fractions of a second off from the actual beat. So for example, you could shift the first kick in a loop to trigger just a hair after the loop begins playing. What is nice about this is that you can mess around shifting the sounds until you get a nice natural "groove". It seems to me that quantitizing just sort of randomizes the timing a little, and you can't get as natural sounding beats.
Old 06-25-2002
gascap gascap is offline
Senior Member
gascap is on a distinguished road
I came up with a good sound when, after quantizing, went back through the song and played the snare hits again by hand - like Lord Wan suggests. BUT, with the quantized snare track along side of the slightly imperfect "hand made" hits, it created a great type of flam sound - a bit like Stewart Copland. i was pleasantly surprised.
Old 06-25-2002
cordura21's Avatar
cordura21 cordura21 is offline
370HSSV- 0773H
cordura21 is on a distinguished road
here's a good article by Craig Anderton.
tempo track tweaking
THE KEY TO SEQUENCED SUCCESS
Subtle adjustment of your tempo track is a much overlooked way of changing the mood of sequences. CRAIG ANDERTON explains how to do it. (more... )
"A woman in a bicycle, with a straw hat, is the most flagrant violation of the laws of aerodynamics." (Dr. Vaporeso)
Old 06-25-2002
esactun's Avatar
esactun esactun is offline
Dedicated Member
esactun is on a distinguished road
Great link, cordura21!
I had just tried that "1 BPM" technique about two weeks ago on a test recording, and it works great.
Old 06-26-2002
Newbie
Also, if you have each drum instrument on a separate track it is very easy to adjust respective timing of each track. Just slide the Time parameter on the track pannel : with postitive value the drum is behind, with negative value the drum is ahead.
( Since no event can occur before measure 1, your song should start on measure two so you can try negative values on timing offset. )
Beside timing, there is other areas to explore when you are seaking the Graal... oups, the Groove.
I think the respective volume ( or velocity ) of each notes can change a dull robot ryhtm to a rolling grooving beat. This leads to the ghost notes domain. For exemple : a heavy kick hit could have a second quiter note to simulate the bouncing of the pedal.
Old 06-26-2002
ChuckU's Avatar
ChuckU ChuckU is offline
RIP DAFDUC
ChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond repute
Human drummers tend to rush slightly before a fill, so sliding the last few notes back in the bar ahead of the fill can give this feeling.
If I'm using 120 ticks per beat resolution, two hits (second one with higher velocity) 8 ticks apart, produces a good flam.
"Don't taze me, bro. Don't eeeeyyaaahhhh...."
