Using Soundfonts with MIDI drum tracks
While surfing this site I found a great thread that discussed using sound fonts to enhance the sound of MIDI drum tracks. The only requirement is that your sound card accept MIDI input and be able to use sound fonts.
Background - I'm using SONAR 2.0 running on a 1.8 Mhz Pentium IIII computer and have an Aardvark Q10 connected. I composed a MIDI drum track using the Session Drummer that comes with SONAR and managed to get the sound chip on my mother board to play the drum sounds. Eventually I guess I'll have to run a connector from my computer's line out jack to an input of the Aardvark in order to record the drum sounds to an audio track. Now to my problem/question. Following the instructions in the thread I mentioned above, I'm trying to use the sound fonts instead of whatever stock synthesis routines the mother board sound chip has, but no luck. When I pull down the Options menu in SONAR the sound fonts option isn't highlighted leading me to believe SONAR has already figured out that my sound chip doesn't support sound fonts. Is this a good assumption or am I completely off base about how this whole MIDI/sound font thing operates? Bottom line, I'm trying to produce some great sounding drum tracks and would like information on how most people approach the task. Thanks, Phil |
But in Sonar 2.0 LiveSynth Pro is only a demo. You can use it in 30 days, after that it will only accept soundfont-banks under 1 MB. Why not buy a SB Live! or SB Audigy soundcard. They're cheap and got built-in soundfontsupport.... Good luck!
Two wrongs don't make a right, but two Wrights once made an airplane... |
Thanks Moskus, that sounds like the best solution.
Phil |
Before you run out and buy a new card, you could also consider buying Livesynth Pro. It costs around $50 if you buy it through Scott Garigus' website:
http://www.digifreq.com/digifreq/rev...ProdReviewID=8 I'm not sure of the pros and cons of a second sound card vs. Livesynth pro. But, I have the software and it works great. By the way, to record your MIDI sounds to an analogue track you don't need to physically connect anything with a cable. Just send your output to the MoBo's sound chip, and set your Q10 to record the MoBo's output directly. This way you avoid any degradation due to converting the digital to analogue and then back. You can do the same with sound fonts.
------------- Dave Aardvark Q10 Cakewalk PA 9 Athlon 1.4 Ghz Asus A7M266 MoBo with integrated sound Matrox G450 video 256 meg Ddram 700 meg WD Caviar C: drive 40 GIG Quantum Fireball data drive |
neirbo, can you explain your assertion that "to record your MIDI sounds to an analogue track you don't need to physically connect anything with a cable. Just send your output to the MoBo's sound chip, and set your Q10 to record the MoBo's output directly."
In my experience this doesn't work. I have an SB Live and a Delta 66 and there is no way to route its output internally into the Delta 66. I would suspect that the same state of affairs exists for an onboard sound chip. What can be done is that the MIDI sounds can be recorded to the audio device that's playing them -- that is, with my SB Live I can record MIDI parts to an audio track via the SB Live's WAV input channels. |
the pros and cons
the pros and cons of a second sound card vs. Livesynth pro:
a card pros: zero latency, no CPU load, you can create your own SFs cons: requires a PCI slot and an IRQ Livesynth pros: you don't need to install any hardware cons: extra CPU load (= less tracks and/or effects), the price is 2 times that of SBLive value card |
I got a SoundBlaster Live yesterday. It got a me just a little closer to using soundfonts but apparently there's more to figure out.
At least now when I open the Options file I have the soundfont option and can use the attach option to open the soundfont file I downloaded. The problem begin when I try to use some of the different patches within the soundfont file. Althought I can select different patches it doesn't change the drum sounds at all. When I open the piano roll view I don't see the midi notes either. Obviously I still don't have something right. Here are the steps I performed: - Open a new MIDI track, make it track 1 - In the track pane under effects, open Session Drummer - Select different patterns and hit play until I find one I like - stop play Options->soundfonts->attach->acoustic drums#1->open->close In the track pane view: - Channel = 1 - Bank = Acoustic Drums#1 - Patch = tried several different numbers - Bank Select = Controller 0 - Port = SoundBlaster (there are four soundblaster options, I chose the first one. A final question. When I tried to use the Douglas Drums soundfont everyone raves about, I get a "Not enough soundfont memory to load the soundfonts" message. Is Sonar trying to tell me that the sound card doesn't have enough memory or that Sonar hasn't reserved enough memory? The font is approximately 22 MB. All comments are appreciated, Phil |
I'm at work, so I can't help you as much as I could if I were home, but here's some clues...
audiohead,
One of your pros and cons re using an SB Live or a softsynth like LiveSynth to play Sound Fonts doesn't fly: "you can create your own SFs." Sound Fonts are just data files. All you need to create them is raw material -- WAV files -- and a Sound Font application like Vienna Studio. Sure, Creative Labs packages a copy of Vienna with the software for these cards, but it's readily available off the web for free, as are other Sound Font editors. -AlChuck |
In any event, the main point is that you can record the MIDI output as audio without using cables or going through digital/audio/digital conversion.
I've gotten a little further...
I was able to open the SB Live control program and change the buffer size so that it would accept larger soundfonts. I also fixed a few fatfinger mistakes in things like channel selection - thanks Moskus. I can now select the various patches within the selected sound font and hear the differences. Quite a few of the patches seem to be repeats but I suppose that's normal. Next I'll work on Neirbo's suggestion for internally routing the Soundblaster output to a SONAR audio track. Thanks guys!!! Phil |
#12
I guess I'm still confused about how to get the SB Live! output into a SONAR track without using external cables.
My only guess is that you could record the output of the SB card to a wave file and then import the file into a track... |
#13
It isn't that tough. First, make sure your SB Live is listed in the "drivers" tab under Options/Audio. In tracks view (the main view) in Sonar, chose an empty audio track. Expand the track vertically to see all the ins/outs, effects etc. Click the box labelled "in" to tell Sonar where to get the audio source from and chose the SB Live.
Next, set your MIDI data to play through the SB Live's output. This is probably set up already, but you can do it under the Options/MIDI tab if necessary. Arm the empty audio track and hit record That's all there is to it, unless I'm forgetting something. I'll check tonight at home and make sure.
#14
Yeah, that's it, neirbo... no importing necessary. Record 'em with the SB Live's WAV device, play 'em back through whatever you want.
#15
#16
Assuming you have the Lives audio drivers working in Sonar - you can record the soundfonts including the cards effects by selecting "What U Hear" as the record source in the Creative mixer.
"Some of the Patches sound the same" Sonar has a defect - it cannot read the soundfont patch names for percussion within a bank. There are only 6 or so drum kit patches which are spread out - in the gaps, you continue to get the previous patch. To find out where they really are you need to audition them in the creative keyboard app. You have 2 soundfont synths, A and B. They share the same soundfonts but you get 32 midi channels that way instead of just 16. Unfortunately, Sonar will only use one of them. It seems Sonars Soundfont support is based on the old Creative AWE card which had the one soundfont synth and stored them in memory on the card itself. I'm afraid I got so annoyed at these quirks that I dumped the Live card.
As one door closes, another one slams in my face. |
#17
audiohead,
You mean you can't hear the SFs you make within Vienna Studio unless you have a Creative card? A LiveSynth won't do it? -AlChuck |
#18
#19
Of course, am I nuts? thinking Vienna would support DXi...
#20
#21
It's probably not that hard, more likely it's that Creative Lab's licensing for it is too onerous, and there's a Windows standard -- DLS-- that does essentially the same thing...
