Old 06-22-2002
bs717779 bs717779 is offline
Newbie
bs717779 is on a distinguished road
Question Mixing MIDI tracks : how ?
I'm new to cakewalk (audio Pro 9).
How can I do the *very basic* action of mixing 2 or more MIDI tracks to one new MIDI track ?
I spent some hours trying that edition, but I did not find any way to do that.
Perhaps I've been missing something ?
Can someone help me ?
By the way, I've been using SmpteTrack on Atari ST for a long time and I would like to find the same features in Cakewalk, perhaps with CAL macros ?
Thanks !
Old 06-22-2002
acidrock's Avatar
acidrock acidrock is offline
Purge's arch nemesis
acidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond repute
Could you please explain why you would want to combine two midi tracks?
If you do they will both play the same instrument,if you're working with a multi-timbral instument(as most are these days)you get 16 tracks of different instruments.
you could just drag one track on top of the other,there's probably a better way but this will work.
Old 06-22-2002
Newbie
If I record 2 piano parts in MIDI tracks (for instance, left hand and right hand separately), how can I mix these two MIDI tracks in one MIDI track ? Ok, it will play the same sound but it's what I need.
Another example, how can I mix all the drum parts (splitted with 1 drum instrument per track) into one global drum MIDI track ?
Perhaps with a CAL function ?
I'm afraid Cakewalk has less capabilities than my "old" SmpteTrack software on Atari ST ... released in the 80's !
Anyway, all tips are welcome.
Thanks !
Old 06-22-2002
Newbie
Talking
I have just found the way to do it :
1. Select all the MIDI tracks to be mixed
2. Copy (ctrl - C)
3. Paste (ctrl - V) and select "paste to one track"
Well, I'm just getting used to Cakewalk ... !
Regards.
Additional remark:
If the channel is set to '--' , playback uses the default MIDI channels defined in the MIDI events.
If the channel for the track is set to 1 thru 16, this channel overrides the original channels assigned to the MIDI data (visible in the event window).
