Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 06-19-2002
L'espion Noir L'espion Noir is offline
Force of Nature
L'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond repute
Angry triton Sampler
triton brethrens
could someone please show me how to use the sampler on the tritron
i've got this kid who write lyrics with sample from movies (mainly)in mind
so i'll have to use the damn thing but the manual has not be cooperating
guidance
Old 06-20-2002
laj35's Avatar
laj35 laj35 is offline
Force of Nature
laj35 is on a distinguished road
What exactly are you having trouble with?? The whole shibang or what???
Laj
Old 06-20-2002
akai akai is offline
Newbie
akai is on a distinguished road
want u just sell it to me !lol
Old 06-20-2002
Force of Nature
The whole shibang is what i'm having trouble with
thanks
Old 06-20-2002
laj35's Avatar
Force of Nature
OK, I'll give it a shot, but I'm at work and some of the particular terms/names might be not quite exact, sorry....
1st, connect whatever source you want into the stereo (1/4") inputs labeled, err....inputs.
2nd, go into sampling mode on the Triton. You should be in the main recording screen for sampling, with a left and a right visual monitor of the incoming signal. You won't be seing it being monitored yet, as you have to set it up to record first. In the upper right hand part of the screen are drop down tabs labeled something like "input setup" or something to do with that, select in one and set them to "L/R"
3rd, hit record once. You should now see the monitor levels start reading the level of the incoming signal. Trim the level so as to make sure it isn't clipping, basically about 3/4 of the bar full.
4th, hit start. You are now recording, do so until you please, but beware you are limited by the amount of RAM you have installed on your Triton.
5th, sample editing. Now comes the fun part. Hit the menu button and select the "sample edit" tab. You should now see a graphic rendering of your sample as a wav. You can brush the sides of the start and finish, as well as the start and finish of the loop points.
6th, convert her to a program using the drop down tab in the upper right hand corner, apply effects, etc.
--Again not completely spot on, but hopefully this will help get you started, and pick through that manual, it's like learning a new language, but one you NEED to be able to fully utilize your new weapon of mass.....err...sorrry.....
Laj
Old 06-20-2002
Force of Nature
Thanks laj
i'm currently at work so i will let y'all know how it went as soon as i get to the lab
Guidance
Old 06-20-2002
Force of Nature
i'm using a mic for input
but laj i didn't get this
<2nd, ...... In the upper right hand part of the screen are drop down tabs labeled something like "input setup" or something to do with that, select in one and set them to "L/R" >
in the preference tab an option is to set it to "L/R" is this what i'm looking for.
when i hit record i don't see see the monitor levels start reading the level of the incoming signal. is it visual
so i don't think i'm recording anything
i really like to get this even if not for me cuz when my man rhymes and he adds those one liners.. it's too phat not to wanna do it
again thanks for your help
Guidance
Old 06-21-2002
Alphonso Alphonso is offline
Profound
Alphonso has a reputation beyond reputeAlphonso has a reputation beyond reputeAlphonso has a reputation beyond reputeAlphonso has a reputation beyond reputeAlphonso has a reputation beyond reputeAlphonso has a reputation beyond reputeAlphonso has a reputation beyond reputeAlphonso has a reputation beyond reputeAlphonso has a reputation beyond reputeAlphonso has a reputation beyond reputeAlphonso has a reputation beyond repute
what I did to learn
There is a tape you can order for the triton that helps get the basics out the way. It is a little expensive and it only covers the basics for each mode. Order from this number 1 800 590 0014 Good luck
Old 06-24-2002
laj35's Avatar
Force of Nature
In LA for a coupla days, will get back at ya!!!!
Old 06-25-2002
Force of Nature
thanx laj35
Old 07-14-2002
Force of Nature
ok we getting somewhere
.. well almost ,when i'm recording something's happening when i
time is taken off the total sample time
but i don't see the "You should now see a graphic rendering of your sample as a wav" Laj35 is refering to
could it be my mic
any input is appreciated
thanx
