I have a Delta 1010 and Cakewalk SONAR. How can I set up a click track for a drummer to play to? The 1010 has MIDI in and out, but none of the Cakewalk Session Drummer stuff or Metronome stuff seems to work. Do I need a separate MIDI card for this to work? I think the 1010's MIDI connections are just through connections and not actually converting the MIDI. Is this right? And how much would a card for this cost me? Can I use a cheap audio card? Why wouldn't the 1010 have this?
Not a big fan of MIDI clicks (or internal software generated ones), unless the source of the click is in the same unit that your playing on , i.e. a keyboard.
There are many free software drum programs out there, that you can create a click in, and then export a wav file. Then import into Sonar. This has a few advantages: - controlling the volume of the click via fader instead of endless dropdown menu's. - a more stable click - makes you think more about 'how fast should it really be'... after exporting a dozen times... Thats a joke, not a real point. Anyway, give that a go. www.fruityloops.com Is one, http://www.threechords.com/hammerhead/ another, never used it though. Or.. If you have a drum machine kicking around, wipe the dust off it, and use it to generate a solid click via output to an input on the 1010. Record it to a track, put down the scratch guitars, vocals whatever, do the drums and rock out! |
The cheap and dirty workaround is to take a .wav file of a cowbell hit (or record one), edit it, then paste it into a track on beat 1, 2, 3, & 4. Then copy the entire measure and paste it repeatedly until your track is filled. You can take 4 & 8 bar measures and copy/paste them pretty quick. Use grid snap to ensure accuracy.
Of course, you don't wanna mess with tempo after that. ![]() |
....none of the Cakewalk Session Drummer stuff or Metronome stuff seems to work....
To be able to play Cakewalk Session Drummer or Metronome, which in Sonar is MIDI-based (or any MIDI file for that matter) you need a device which will generate the sound for you. It may be a hardware card with an on-board synth such as Soundblaster or a software synth such as LiveSynth or Roland Sound Canvas (bundeled with Sonar XL) or an external synth. Then you even will be able to connect a MIDI controller to your Delta MIDI inputs and play it. |
Heinz is right. And screw trying to get midi stuff to work. You have a 1010. Record something. A cowbell hit, spoon on a glass, kick the dog, whatever.
But instead of cutting and pasting a bar, make it a groove clip and stretch it thru the song. And if your tune has tempo changes, your clip should adjust with it.
"Don't taze me, bro. Don't eeeeyyaaahhhh...." |
(beavis voice) ooohhhhh yeeeahhhh.... uh huh nnhh huh huh... groove clips... unh huhuhuh huhuh..... cool...
Kick the dog? He said "click" track not "kick" track hee hee- certainly would stand out in the mix though. |
I took your advice and recorded some drum sounds from my Casio keyboard, a little kick and snare, boom - tah, boom - tah, etc.
I made that into a groove clip and looped it, the problem was, no matter where I cut the audio up to make the groove clip I got this gap of sound between each loop. I tried messing with the Tempo setting, but it didn't remove this gap. Does anyone know what this is from? |
