Go Back   Home Recording > General Discussions > DJ & Hip Hop Production
Reply    Audiofanzine Dj Dj News Dj Medias Dj Tests Dj Articles Dj User Reviews Dj Classifieds Ads
Old 06-03-2002
stray411's Avatar
stray411 stray411 is offline
1K Silver Member
stray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond repute
Bass issues:
How do you guys/gals go about getting that "way too big" bass and kick combination? For kicks are you mainly using an 808 kick? How about bass, is it normally based off a Sine wave? Are you compressing the kick and/or bass before using and if so do you compress them together or separately? If not when compressing them afterward do you do them together or separately?
Sorry about all the questions. Any help would be greatly appreciated as I'm just getting started with Hip-Hop production (I've worked with other genres for years) and there are a few things I'm a little unclear on.
Stray
Old 06-03-2002
pyssdogg pyssdogg is offline
Junior Member
pyssdogg is on a distinguished road
-man, you jus have to experiment
Old 06-04-2002
crosstudio's Avatar
crosstudio crosstudio is offline
Reggae + Go-Go = Regg'go
crosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond repute
compress them suckas individually.
then use a C4 multi-band compressor in the mastering process and compress the lows as a region.
scoop out the 250-500hz area so you can add (if necessary) some thump in the 80hz area.
Old 06-07-2002
stray411's Avatar
1K Silver Member
Thanks for the reply:
Thanks Crossstudio, I figured it was probably common to compress first. I'll experiment with some different compressor settings. I have relatively good levels as we speak I'm really just nit picking and I just wanted to see if anyone here had some tips/tricks I could utilize. I talked to the mastering engineer the other day and he said I will notice a pretty big difference after the mastering process.
Thanks again
Stray
