Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 06-03-2002
Kclark01 Kclark01 is offline
Newbie
Kclark01 is on a distinguished road
Bass sounds from a guitar?
Can anyone recommend a method for producing a decent bass track with a guitar? Effects pedal? Plugin? I use a Taylor acoustic/electric through a Mackie 408M powered mixer and a Strat through a TopHat King Royal.
I've seen but never heard a Boss Octave pedal, which is supposed to produce 3 tones, one an octave above, one an octive below, and one 2 octaves below the original tone. The level of each tone is adjustable, but I'm not sure if you can reduce the level of the original tone so that all you hear is one of the lower tones by itself.
Any recommendations, advice, insights one the best way to do this?
Thanks, guys
Old 06-03-2002
frederic's Avatar
frederic frederic is offline
frederic.midimonkey.com
frederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond repute
If you need to do this for a recording (i.e. in the short term) I would recommend heading down to your local family owned music store and renting a basic bass for a week or two.
Renting gear is a great way of getting what you need when you need it, for a specific project.
If you want to do this ongoing, the Boss unit sounds pretty good, but I wouldn't use it in a studio - one can hear a little grunge if you are careful.
Through an amp its not too bad.
Old 06-03-2002
Gidge's Avatar
Gidge Gidge is offline
Lapdance Test Dummy
Gidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond repute
Cool
just get a cheap bass...fairly decent ones can be had for $100-$150 new, cheaper in the pawn shops....
Old 06-03-2002
Newbie
I've thought about getting a "cheap" bass but have decided against it for various reasons; the biggest reason being that it's kinda hard to hide another instrument from my old lady...and money's a little tight right now since we're in the middle of renovating our house. An effects pedal would sorta "blend" in with all my other pedals and go totally unnoticed...In a pinch, I could even toss a sock over it for quick concealment. A plug-in would be even easier to hide--just hit alt-F4 if I hear footsteps : )
Old 06-03-2002
Gidge's Avatar
Lapdance Test Dummy
Cool
what are you recording on?....if you are on a pc you could do a midi bass track....
way back when i was in the same predictament (spelling?) and i went with midi bass and drums until i could afford better......
Old 06-03-2002
Whoopysnorp's Avatar
Whoopysnorp Whoopysnorp is offline
Huh huh..."member"
Whoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond repute
The band Local H is just a guitarist and a drummer. The guitarist splits the outputs from his axe (I don't know what he uses, unfortunately) into a guitar amp and a bass amp. It sounds pretty good. Not quite like a bass, but similar. On the CD that I have by them, there's a picture of the guy's pedalboard behind the CD tray, and among the effects is a Boss Octaver. I've also used this box, as my dad owns one. It's pretty cool. I've never played with cancelling out the original tone, though.
Old 06-03-2002
Newbie
I'm recording on a PC, but I tend to shy away from midi for bass lines with all the acoustic guitar stuff I'm doing...The artificial sound of it seems intensified when coupled with acoustic guitar I think.
The Boss Octaver seems like the way to go... Mars Music has them new for $90, and I've seen a couple on Ebay for around $50 plus shipping. If I don't like it, I can always put it back on Ebay I reckon. I'm just getting into this--using N-track with SBLive. So, with soundcard upgrades and all that to think about down the road, I'm gravitating towards a cheap solution for the time being, and it looks like the Octaver is it, unless there's a decen plug-in around.
I'd love to hear some of that band Local H. I wonder if they have anything posted on the web.
Thanks, guys.
Old 06-04-2002
adam adam is offline
Dedicated Member
adam is on a distinguished road
Other than the suggestions above -- buying a bass, pedals, etc. , I've gotten good results with guitar, and bassy eq set up. What helps is heavier strings -- I use 11-52s. Also, attacking with your thumb helps too. Remember bass is just not an instrument, it fills a specific space in the eq spectrum.
If you go to this link http://www.home.earthlink.net/~adamcrose/index.html, you can listen to 'closer' - The main riff is just an old danelectro 1 p/u guitar (24" scale) with 11's, tuned regularly. When people hear it they often think it is a bass. I used a rocktron pro gap and power amp into a marshall 2x12. The eq setting was full out bass, medium-high treble, little mids (scooped sound). Usually I don't like this sound for guitar, but for something like this it worked well.
I've also had good results using a 1x15 speaker and another guitar.
I am just trying to suggest things that won't require additional purchases.
my music: adamrose.org
Old 06-04-2002
Newbie
Thanks for the suggestion. This link was expired or something... But I can try messing with my acoustic/electric, which has 13's on it. If I put 11's on my strat, I'd need some superglue for my fingertips-- ala Stevie Ray. :-)
Old 06-04-2002
Dedicated Member
sorry, a comma got in there. http://www.home.earthlink.net/~adamcrose/index.html
Old 06-04-2002
Newbie
Nice songs--very fresh and creative.
Thanks again.
  #12
Old 06-05-2002
Dedicated Member
Thanks for listening and for the feedback. I noticed you live in Richmond. There are a few others on this board too from there.
I am hoping to move there from NYC within the year.
How do you find the music scene? Do you find that there is a good community of musicians?
  #13
Old 06-05-2002
Newbie
Richmond is a very low-key, conservative place. A great place to raise a family and to swap any NY real estate investment you may have for a sprawling estate, by comparison (I have family in Great Neck and a buddy who moved here from eslewhere in Long Island). I've lived here all of my 32 years and have a fairly good knowledge of the comparitive merits of the different areas of the city should you ever have any questions.
I haven't been much into the live music scene since getting fat and domesticated a few years back, but I've seen the live offerings improve greatly since an old, pre-Civil War warehouse area of the city was resuscitated a few years back with the construction of a federally funded floodwall, which stopped the James River from swamping the whole area about every couple of years. All these old warehouses were converted into bars, restaurants, and clubs. The area's called Shockoe Bottom, and you can always find a variety of live acts on most any given night. Every time I visit this area--about every 3 months or so--it seems to have expanded. I hope the trend continues, because the place has sort of a bohemian, New Orleans feel to it (but don't expect anything close to Greenwich Village or New Orleans.
A couple miles west of this area is the VCU/Fan area, where townhouses and a bohemian feel also predominate. VCU (Virginia Commonwealth University) has an acclaimed music program, with lots of associated events and cool things emanating from it.
Richmond has the usual array of music festivals and such scattered throughout the year that are quite worthwhile, especially June Jubilee, which should be starting soon. National acts do come here, and there are some wonderful venues for them, large and small.
If I had to describe the modest Richmond music scene briefly, I'd say it's eclectic. Although Richmond is an old Southern capital, it's also within 500 miles of half the entire population of the US. That makes it quite a cultural crossroads (even though certain areas seem extremely WASPy). In fact, Richmond is constantly being used as a "test-market" by many companies that recognize the variety of its population's make-up. The music scene seems to reflect that variety: just about every genre seems to have it's own "society"--I personally belong to the "blues society" and try to bring my axe to as many free-jam's as possible, though I'm slacking lately.
(Sorry if I'm going on too long, but I'm not sure what your aspirations or interests are musically)
The last few times I caught live shows in NYC, I noticed them passing a hat (or bucket) around between sets to fund the band. It doesn't work this way in Richmond. I know several professional acts that make a living playing live (without a day job, even). They get like a flat fee plus a percentage of the door plus a percentage of the bar--or whatever combination they negotiate for. This one girl I know gets like $500-$1500 a night (depending on where she's playing and whether she's doing it solo or with her 4-piece band), and she works 5 nights a week...2 weeks off for vacation. Imagine!!!!!!
The proximity of Richmond to D.C., Baltimore, Virginia Beach, etc. is kinda cool in that if there's a national act or something you're interested in that's not around the corner, you're a short ride away. (And during your trip home you can giggle at those folks who spent as much on their 2-bedroom Georgetown condo as you did on your 3-story, five bedroom, 1.5 acre country club home in southside Richmond--with some of the best public schools in the country I might add).
Well, anyway, hope I've given you some insight. Lemme know if I can help more. I do know a bit about the area...where to get the most "bang for your buck" in terms of buying a house and things like that. My email is kclark01@comcast.net.
Good luck!
  #14
Old 06-05-2002
Shinobi Shinobi is offline
Junior Member
Shinobi is on a distinguished road
Talking Wow...
Seems like you dropped a Chocolate Log. ;-)
  #15
Old 06-06-2002
Newbie
Why, yes. About halfway through a 12-pack I start typing away for some reason. Since you mentioned it, here's the recipe:
Chocolate Log Recipie
null null
2 pkts. plain biscuits
1 pkt. walnuts
Plain Chocolate
6 tbs.icing sugar
3 tbs. hot water
3 tbs. drinking chocolate powder
Brandy
Crush the biscuits into crumbs, cut walnuts into chunks and mix in a bowl. Add the icing sugar, drinking chocolate powder and some brandy to taste. Mix everything together and mix and mould into a shape of a log. Melt plain chocolate and cover the log. While chocolate is still warm pass fork over it to give the effect of a log. Enjoy
  #16
Old 06-06-2002
Evildick's Avatar
Evildick Evildick is offline
Dedicated Member
Evildick is on a distinguished road
Didn't GWAR come out of VCU? Richmond, if you don't get shot or thrown into a bible study class, is a very nice place. It helps if you have a car to drive away from it.
  #17
Old 06-06-2002
Stefan Elmblad's Avatar
Stefan Elmblad Stefan Elmblad is offline
Force of Nature
Stefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond repute
The BOSS pedal produces the following three tones:
1 tone 2 octaves below
1 tone 1 octave below
1 tone original pitch, in reality just a direct out.
  #18
Old 06-06-2002
Evildick's Avatar
Dedicated Member
Is that Octave pedal similar to the old Octopus pedal with more flexibility in terms of octave manipulation?
  #19
Old 06-06-2002
Force of Nature
Don't know what you mean about flexibility, it justs creates 2 additional tones which you blend with the direct out via 3 volume knobs - that's it. The thing to go for in an octave pedal is fast and good tracking of notes which I believe the BOSS manages to do.
  #20
Old 06-06-2002
Newbie
Yeah, GWAR came out of VCU...So did I for that matter. The dangerous area is a few miles east and is pretty concentrated (I used to work on an ambulance crew in that area.) So, far I've avoided both getting shot and being thrown into bible class; although, I did once go to a titty bar that was across the street from a Pentacostal church, which is as close as I've gotten to bible class thus far.
  #21
Old 06-06-2002
Dedicated Member
Wow!! Thanks for the long reply. Good information and thanks for the offer of letting me know more about it. I have some friends there and visit a few times a year. Y
ou are in the blues scene so I will venture to play the game of "You're from x do you y..."
Do you know a bar in the bottom called Medly's/Medlies (Sp?)? They host blues bands all the time. My friend Rebecca is the bartender there on the weekends I think Th-Sun. Have you been there? It is run by this ornery woman, I can't remember her name.
I've been to a few titty bars there, 3 different ones. One actually used to be a sizzler or something and the girls dance on the salad bar. Funny time. To bad about the "t-bar" and "pasty" rules.
Yeah, the cost of living is a HUGE plus. I am tired of working a day job, making great money (so does my wife), and living in a 1 bedroom apt. My "studio" is a walk in closet. If we bought something here I feel like it would be signing my death certificate, or at least my application to the bitter, overweight, middle aged man club. I feel like I'm half way there already (I'm 28). lol! I would be a slave to a mortgage.
Tried to work out a transfer with my job and it looked good until Enron hit the fan, the economy is slow to recover, and my company is going through a spin-off. If my wife or I get laid off one of us will move to Richmond, get settled, and then the other one would move too.
Finding a job in Richmond, especially remotely, has proven difficult. My wife probably has the best shot as she has financial services experience. I work in strategy consulting. There are a few companies there, and the Martin Agency would be cool. No luck yet.
  #22
Old 06-06-2002
Newbie
I haven't made it to Medley's yet; there's an open jam on Sundays at Legend's Brewery I've been to. A good place to see live acts, if you haven't been there already, is Poe's Pub about a mile east of the Bottom--they have the most interesting variety of acts of any place I've been to. Good ribs, too.
Yeah, I've been to that former Sizzler, lol--"Richard's Rendezvous." Not the best one in town by far, but fun in a tacky sort of way.
Your wife, and perhaps you too, might want to check into Capital One--they're centered in Richmond. Circuit City has its HQ here, too, as does SunTrust I think. It would definitely be cool to work for the Martin Agency, if only because their building and location are so killer. The only corporate recruiter I know deals strictly in I.T., but I'm sure there are some posted on the web. Both my brothers-in-law got jobs in Richmond fairly quickly by working with a headhunter. In case you haven't looked through the local classifieds, the Richmond Times-Dispatch has them online: www.timesdispatch.com.
My wife used to teach finance at VCU and says that they have a large marketing department and you might want to call a professor, explain that you're looking to relocate, and ask if he/she can suggest a "short list" of employers in your field. She says this is done all the time and that you might just get lucky should the professor feel like offering you some actual contacts. Just a thought.
  #23
Old 06-06-2002
Pirateking Pirateking is offline
Senior Member
Pirateking is on a distinguished road
Weird, I live in Richmond, never noticed anyone else from here posting on this board.
I've only lived here a year (lived in Williamsburg for 4 years before that, which is 45 minutes away), so I might not be as big an expert, and will basically be reiterating what was said above. Job situation here is pretty crappy, my girlfriend (who has a degree from William & Mary) looked for 4-5 months before being offered a full-time salaried job that she could stand. But then again, it only took me a couple of weeks, so I guess it's all about luck. The low cost of living is the biggest advantage, the Fan is great, cheap, and cool. But be sure to look around a while before you pick an apartment to make sure you get the best deal, prices are going up. And stay away from River City Real Estate if you can, they kicked everybody out of our building 6 months after we moved in so they could renovate and charge higher prices (and they notified everybody about this THE WEEK BEFORE CHRISTMAS!). Look for a place being rented out by an individual rather than a company if you can. Another advantage is Plan 9, probably one of the best music/cd/record stores on the east coast, especially if you own a record player (they have a HUGE $1 record section).
Now the bad stuff: I'm into indie rock/punk/obscure weird music, so that's the background I'm coming from. The underground music scene is almost all VCU kids, and very based in hardcore punk - GWAR came out of RIchmond, but so did Avail. The liquor laws for clubs are very stringent, so clubs that let small bands play come and go very very quickly. The guitar store selection ain't that hot either, there's a Mars (blah) and a couple of smaller places that are crappy. My personal favorite is Candyland, which is small, very cluttered, all used stuff. The owner is a nice guy, he doesn't always have the best info though so do research beforehand. I've also had problems finding a practice space. My friends and I have been practicing in Williamsburg after having given up on looking for one here.
Personally, I love Richmond so far, but it can be frustrating.
Anyhow, if you have any other questions, feel free to email me too: naamme@yahoo.com.
  #24
Old 06-06-2002
Newbie
Hey Pirateking,
I always go to Guitar Works on Cary St., then to Metro Sound on Broad Street; then, once I've made a shopping list, I call Chuck Levin's Washington Music Center in Rockville, MD and have them ship me whatever I want for nearly half the price, tax free. Their prices blow anything in town or anything I've seen online out of the water. And their shipping is rediculously low. They have a website, but don't post the prices. They'll email you the price on request, though. Check it out; the place is amazing.
  #25
Old 06-07-2002
Senior Member
I actually lived outside of DC for a few years, so I developed an extreme aversion to Chuck Levin's because the salespeople there were always nasty. I guess that's the bonus of ordering online, though. I'm kind of a used/vintage instrument fetishist, so that's why I prefer Candyland (and Atomic Music in DC, the holy grail of used guitar stores) to those others. I have never seen anything I was remotely interested in at Guitar Works or Boykins (on Broad). Seems like maybe Guitar Works makes most of their money from repairs or something, because their selection is horrible. Metro Sound seems pretty decent, I've never bought anything there, but they seem to have an ok selection of cool used stuff. One that bothers me is that they're one of those stores that puts their coolest guitars (read: the old vintage guitars that probably don't even work) on the wall as a display instead of selling them. That pisses me off. But other than that, it seems ok.
