Old 06-01-2002
c9-2001 c9-2001 is offline
1K Silver Member
c9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond repute
Observation window/Booth
i'm about to start building my vocal booth...what type of glass should i use for the window? and where can i get in, and how much will it cost me?
Old 06-01-2002
Beathoven's Avatar
Beathoven Beathoven is offline
Certified Lunatic
Location: Lemme school ya'll permanently like a motherfuckin' tatoo!
Beathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these parts
You need two glass windows angled like that:
| &nbsp&nbsp&nbsp/
| &nbsp&nbsp/
| &nbsp/
The two windows must be of different thickness. There's no fixed value for that but people seem to like 1/4" mixed with 3/4".
You can find more on that at:
http://www.saecollege.de/reference_material/index.html
Peace,
Beathoven
Old 06-01-2002
ausrock's Avatar
ausrock ausrock is offline
Feeling Monolithic
ausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond repute
C9,
Ideally there should be no physical contact between each sheet of glass or wall frame.
Yes, use two different thicknesses.........6mm (1/4") and 10mm (3/8") are fine, but put the thicker at the sound source side.
Using laminated glass is preferable, as by nature (it is two thinner sheets with a clear synthetic membrane between), it doesn't have the tendancy to resonate as much as normal "float" glass.
Acoustic tests have shown that angling the sheets is of little value unless they are of the same thickness, and then to be of any use the angle should be at least 12 degrees. Angling does reduce problems of light reflecting back and forth between the sheets and it definitley looks cool.
Old 06-01-2002
Badger's Avatar
Badger Badger is offline
AKA BDGR
Badger has a reputation beyond reputeBadger has a reputation beyond reputeBadger has a reputation beyond reputeBadger has a reputation beyond reputeBadger has a reputation beyond reputeBadger has a reputation beyond reputeBadger has a reputation beyond reputeBadger has a reputation beyond reputeBadger has a reputation beyond reputeBadger has a reputation beyond reputeBadger has a reputation beyond repute
rather than a window, why not just get a cheap web cam. Its cheaper, and oh so high tech.
Old 06-01-2002
1K Silver Member
i don't wanna do that... i tried it with x-10's.. the mic booth is gonna be right infront of me so i'd rather have a window... we'll get 1/4 and 3/8'' then....no ? is were can i buy it? and how much ...the booth is gonna be built out of mdf with acousic foam and bass traps
Old 06-01-2002
ausrock's Avatar
Feeling Monolithic
C9,
I suggest looking for "Glass Supplies" in the phone book.......shop around for the best prices on the sizes you need.
Where the MDF walls are concerned, make them as thick (dense) as possible.
Old 06-02-2002
1K Silver Member
this is only gonna be a temp booth until this fall...
instead of using 2 peices, what about just 1 sheet of 1/2" plexiglass or 3/4" car stereo plexiglass... i order stuff from select products all the time...
http://selectproducts.com/frameindex.htm
i was thinking 3/4" plexiglass would work fine for this temp booth..anything is better than the closet i'm using right now...it has a smooth sound but not a lot of space...
Old 06-02-2002
ausrock's Avatar
Feeling Monolithic
You could try the plexi, but it does have a tendancy to be more resonant than glass.......but the 3/4" might be ok.
Old 06-02-2002
frederic's Avatar
frederic frederic is offline
frederic.midimonkey.com
frederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond repute
Like others said, any glass place. However, i would highly recommend SAFETY GLASS. Its worth the money in preventing people from getting injured should anyone fall into it.
Another reason why beer in studios is bad. LOL
Old 06-03-2002
jimistone's Avatar
jimistone jimistone is offline
1K Silver Member
jimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond repute
i haven't started on my vocal room yet....but i have a really big sheet of glass (not lamenated). I was just going to take the sheet of glass to the glass place and have it cut in half... for my 2 peices of glass for the observation window.
why do they need to be different thickness?
my music...More than 1 song now!!
The movement you need is on your shoulder
Old 06-03-2002
ausrock's Avatar
Feeling Monolithic
Glass of a given size and thickness will resonate at a fairly specific frequency. If you have two sheets the same set parallel to each other, the one on the "sound source" side will set up "sympathetic frequency resonation" in the other sheet. This is why it is preferable to use sheets of differing thicknesses, so they are not in sympathy with each other.
One way to minimise this effect is to mount the sheets out of parallel..............try and get them at least 12 degrees offset. And the thicker the better.
  #12
Old 06-03-2002
darrin_h2000's Avatar
darrin_h2000 darrin_h2000 is online now
Been Here, Posted That
darrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond repute
the angle thing is really just for the parelell wall avoidance, and the fact that it is less likely to cast a reflection, so vocalists wont look at themselves while they should be paying attention to you.
Differing thicknesses resonate at different frequencies. so sound doesnt tend to go through them as eazy.
wayne
  #13
Old 06-03-2002
jimistone's Avatar
1K Silver Member
thanks
