I keep hearing about neoprene. I want to get some for floating floors and walls, but I'd like to find out where to buy it and in what form. Does it come in sheets or rolls? 1/2" thickness seems right. Where can I purchase some? Are prices consistant or is there a preferred dealer?
Neoprene is rubber. Find a local company that makes gaskets and ask them for scrap material. You should be able to come up with many coaster size discs or leftover scraps from full sheets.
at 1/2" thick you should look into copper pipe insulation. at 1.00 for 3" by 6' that will be the cheapest option. and its at all the hardware stores
If you're planning on using this for floated floors, pipe insulation won't work. For optimum isolation, the pads you use on floated floors, or speakers for that matter, should be compressed by about 15%. This gets tricky for unknown materials, expensive for known ones. Auralex sells these "U-Boats" for bedding 2x4's in under a floated floor, but the cost can get carried away pretty quick. Other acoustic companies sell rolls of rubber pucks separated by webbing, that you just roll out and build your floor (either concrete or wood, depending on your dedication/budget - One alternative I'm considering which would cut costs but be a bitch to figure out the loading for 15% compression, is "horse mat" material. It's available at animal supply places that sell tack and feed, etc - it's a 1" thick re-gurgitated rubber mat, usually 4 feet by 6 feet. It can be cut with a skil saw. My plan for testing to see what percentage of compression is, would be to build a "test floor" maybe 1 x 2 feet, find something heavy (100 pounds or more) like barbell weights, and try various amounts of weight/pad contact areas until you found what weight/surface area gives about 15% compression. You then would have to calculate what the entire floating room would weigh with all equipment in it, do the math to find the contact surface area required, and spread this out over the floor joists evenly. Remember only the surface of rubber in contact with the 2x4's counts. Sound like fun? Me neither... Steve
Hey, I thought this was gonna be EASY!??! |
Darrin - have you (or anyone?) used pipe insulation for this? I was thinking of using it to seal the tops of my walls against the ceiling.
Also... The neoprene question has been asked here a bunch of times, so I tried doing a search to reference the other threads but for some reason, I can't seem to find them. Did any of the archive stuff get lost in the software upgrade? Jonothon, Binkleman rubber is one place I remember looking and getting a quote from. http://www.binkleman.com remember it's heavy... shipping adds $$ Kevin. |
http://www.kineticsnoise.com/architect.html download View Architectural Brochure (548 KB)
more tested designs for floated everything - floors both concrete and composite wood/drywall. Ceilings too. Well worth studying and then applied to your own circumstances. Cheers |
