Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 05-17-2002
hk_runner hk_runner is offline
Newbie
hk_runner is on a distinguished road
Question Cubase
Could you tell me where I can download the user manual of Cubase VST? Thanks.
Old 05-17-2002
Lopp's Avatar
Lopp Lopp is offline
[Insert Custom Text Here]
Lopp has a spectacular aura aboutLopp has a spectacular aura aboutLopp has a spectacular aura about
I should be in the directory you installed Cubase into.
Old 05-17-2002
man@work man@work is offline
Senior Member
man@work is on a distinguished road
Hi hk_runner,
If you have purchased a legit copy of Cubase VST you will
find it on the CD in PDF format.
If you have downloaded a demo version,
you will have only the help files within the program.
If you have a cracked version you are SOL!!
Hope this helps!
MIke
Old 05-17-2002
Newbie
Question
thanks a lot.
Is it worthwhile to learn Cubase VST 5.0, now that the new Cubase SX is about to be released? Or should I save my time and wait for the release of Cubase SX?
Old 05-17-2002
Bass Master "K"'s Avatar
Bass Master "K" Bass Master "K" is offline
Force of Nature
Bass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud of
No better time to start. Keep in mind that upgrades are rarely a complete overhaul, they usually add extra's to the original program. I would recommend getting as familiar as you can with the system, that way when you get EX you will be familiar with the basics and better be able to learn the new features with less of a chance of feeling totally overwhelmed by starting from scratch.
Old 05-18-2002
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Actaully SX *is* a complete overhaul and it has changed in terms of functionality and user interface - all very much for the better... it's slotted for release around the end of June... if you buy Cubase/32 now, upgrade to SX is free.... so you can still start to get your feet wet, then still get the improvements offered by SX.........
Bruce
Old 05-20-2002
Lopp's Avatar
Exactly.
SX takes hints from Nuendo and is a complete overhaul of the Cubase system. Also, according to a store tech, the parallel port dongle is being replaced with a USB dongle. Also, supopsedly 5.0 works on systems up to WinME, but SX will only work on XP/2000.
You can check www.steinberg.net for screen shots, etc.
As Bruced mentioned, you will get the upgrade to SX for free if you buy 5.0 before it is released. It is also rumored that you can then run each on different computers because you can keep the original 5.0 software and dongle.
IMHO, it will be worth it just to get more than one level of undo.
Matt
Old 07-15-2002
enemyofthesun's Avatar
enemyofthesun enemyofthesun is offline
Dedicated Member
enemyofthesun is on a distinguished road
Originally posted by man@work
Hi hk_runner,
Hope this helps!
MIke
if this is the case I am saved.. I lost my manual and am looking for a pdf. you say it will be found instaleld on the harddrive or on the CD????
"I've heard your stuff and the recordings suffer from the common ailment of home recording murkiness"
Old 07-15-2002
Chris Shaeffer's Avatar
Chris Shaeffer Chris Shaeffer is offline
Peavey ROCKS!!!!!!!!!!!!!
Chris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond repute
Try
c:\Program Files\Steinberg\Cubase VST 5.0\Documentation
That's about where mine live on the Hard Drive. I don't have the CD here, so I have no idea where you'd find them there. Maybe to a search for .PDF files.
The big manual is called "Getting Into the Details."
Enjoy!
Chris
