Old 05-03-2002
Griffinator Griffinator is offline
Dedicated Member
Griffinator has a little shameless behaviour in the past
Presonus Digitube?
Anyone messed with one of these? I was looking at it as an alternative to the ART DI/O for a single-channel fix for $249 - especially since the 8-channel version is only $1300 when I upgrade later.
Old 05-03-2002
Dolemite's Avatar
Dolemite Dolemite is offline
Force of Nature
Dolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond repute
I presume you're talking about the DigiMax? The DigiTube is a version of the Bluetube with built-in converters. Anyway, yes the Digimax looks nice. There's also the DigiMax LT which looks to be the same unit without the limiter/EQ curve functions, selling for $800 at MF. I bet either one would make a nice front-end for an ADAT or a computer interface with a lightpipe input, like the Digi001 or the Motu units...but some of those are nice front-ends on their own. I think Alan "you can call me Al" Hyatt was coming out with something like this...an 8 channel preamp/converter unit with lightpipe out, based on the Burr-Brown chipset used in the Grace pre's. I think the MSRP was $700, so you'd likely see them for $500ish. Still, it would be nice to have a good limiter on every channel like you get on the DigiMax.
Old 05-04-2002
Dedicated Member
Actually, I was asking about the DigiTube, as I'm looking at purchasing a single-channel for right now, and then save up for the Digimax (if the performance is up to snuff) - I'm definitely looking to use them as front ends for my DAW - I've got an Audigy Platinum with the LiveDrive interface, which takes care of the Toslink (lightpipe) interface, but, for obvious reasons, the suckass converters on the SB ain't going to cut it, so the outboard converter is a must.
Old 05-04-2002
Markd102's Avatar
Markd102 Markd102 is offline
Wannabe Gear Slut
Location: Australia. Almost as far south (mainland) as you can get
Markd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond reputeMarkd102 has a reputation beyond repute
If you don't need the eq, insert point or tube stage, I urge you to check out the Mindprint DI-Port. 2 very clean mic pre's with 24/48 S/Pdif ins and outs (coax and optical). Very versitile little stereo AD/DA convertor, and it's only about 2 thirds the price of the Digitube.
I basically couldn't see the point in wasting two chanels of S/Pdif inputs on a single pre
Mark
Brain Under Construction
Old 05-04-2002
Dedicated Member
Mark
I hear ya - although the tube pre (if it's a good one - I'm not very familiar with PreSonus tubes) to me would be worth that extra $80 in and of itself.
Old 05-06-2002
darrin_h2000's Avatar
darrin_h2000 darrin_h2000 is offline
Been Here, Posted That
darrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond repute
I have an older Bluetube with Jensen tranformers and Its a fine pre. But told the new ones can be noisy. I guess you should try them out in the store first with a good set of monitors.
wayne
Old 05-06-2002
Dedicated Member
Oh, believe me. When my local dealer gets one in, I'm going to take it home and put it through its paces for a weekend.
