Go Back   Home Recording > User Forums by Brand > Alesis Forum
Reply    Audiofanzine Alesis Alesis News Alesis Medias Alesis Tests Alesis Articles Alesis User Reviews Alesis Classifieds Ads
Old 04-28-2002
werewolf831 werewolf831 is offline
Senior Member
werewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these parts
Unhappy My ADAT tape is stuck!!!!
The tape door is half open and tape looks like it is ready to eject. There is an ERROR 00 on the display. Anyone have any advice on what to do without damaging the tape? I was going to power down and then take it to the shop tomorrow, but my ADAT manual says to never power down if the tape is threaded. ANy help would be great....I'll be searching posts in the meantime.
Thanks,
werewolf
Old 04-28-2002
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Sounds like the eject belt snapped....
You should be able to power-down and take it to the shop... or as I did - buy replacement belts and do the replacement yourself! (It's a bit of a pain, but can be done.... just avoid unnecessary motion)
I successfully replaced the belt and recovered the tape.........
Bruce
Old 04-28-2002
Senior Member
Tape repair?
Thanks for the info Blue Bear. Well, I powered down, then powered back up. The tape came right out, but there is about a 6-8" section of tape hanging out of the cassette. One part is pretty scrunched up. Is there any way of salvaging the tape? Will the tape still be playable? Also, the section of the tape damaged is the very beginning of the tape.
Thanks,
Josh
Old 04-29-2002
You should be able to wind the tape up in one direction.... if not, then you'll have to carefully open the shell up and wind it up by hand, at the same time disengaging the tape motion "locks" that are inside to allow the tape to wind smoothly.
Personally, I wouldn't re-use that tape - I'd clone it and throw it away....... and I suggest you do the same (if you have a 2nd ADAT.)
If not, consider renting or buying another! You should ALWAYS do tape backups.......!
Bruce
