I have recorded two guitar parts with my Aardvark Q10 but when I did so I used the same channel (LEFT). I went to pan one guitar to the right and when I do so I lose one that guitar. Is there a way to copy this track to another giving me the ability to pan it either way?
Thanks in advance Goat |
The Q10 inputs are all mono, so it shouldn't matter if you record on a "left" or "right" channel.
Can you be more specific in your question? Do you lose the sound when monitoring (i.e. recording) or on playback? What recording software are you using? Are you panning using the recording software, or the Q10's mixing software?
------------- Dave Aardvark Q10 Cakewalk PA 9 Athlon 1.4 Ghz Asus A7M266 MoBo with integrated sound Matrox G450 video 256 meg Ddram 700 meg WD Caviar C: drive 40 GIG Quantum Fireball data drive |
Sorry for the lack of info! I was in a hurry. I'm using Cakewalk PA9 to mix down. Running a p2 400 win ME lots of ram.
I've done the recording at a friends place and am burning the tracks to cd as waves then using CWPA9 to do the mixing at my house. When I try using the pan in CWPA9 I lose volume when I go the the opposite track to which I have recorded on. My Aardvark Q10 has left, right, and stereo inputs when recording. I selected left for both guitar tracks ( done one at a time) The panning is being done with CW since the Aardvark is not at my place. Nothing was panned while recording. Any advice??? Thanks for your reply neirbo! Out Goat |
Here's a few ideas:
1)Check the pan on your main monitor bus (where you see the output levels in "console view"). Make sure it is centered. I haven't used Cakewalk in a while, so I'm not sure it even has a pan on the main bus, so I could be way off on this. 2) Try diabling any effects or aux busses you have going and see if the problem persists. Sometimes stereo effects can do strange things. 3) Are you sure that "left" was selected for recording? It almost sounds like "stereo" was selected. "Stereo" would require two mics, one into channel 1, the other in channel 2 (or channels 3/4, 5/6 etc.). So, if you only put one mic into channel one, and selected "stereo 1/2" you recorded in stereo, but with guitar on one side (input one) and dead air recorded on the right side (inpput 2). To make sure, in your main clips window (where you see the wave forms), double click the waveform. You might see one waveform and one straight horizontal line. This would explain why you lose the track when you pan. 4) It could be a playback problem. One your main monitor bus meters, you should see the outoput meters from both the left and right output channels. Do these meters change when you pan? If not, maybe you just have a bad connection to yone of your monitors. 5) in the Aardvark control panel, check the output meters. Make sure pans are centered. Note what happens to the meters when you pan in Cakewalk. It will help narrow down the possible problems. Hope one of these helps.
