Old 05-17-2000
psuedo dog psuedo dog is offline
Newbie
psuedo dog is on a distinguished road
Wink
ok people.
im faily new to this, but this is my setup.
i have a tascam p150 pro audio amp, some turntables, a denon smx2000 mixer, loudspeakers.. now the question is...
could sombody please tell me the correct, safe way to set this system up? the amp pushed 150 watts..the speakers take 150 watts.
thanks
Old 05-18-2000
MISTERQCUE's Avatar
MISTERQCUE MISTERQCUE is offline
Not Just Anutha Brutha
MISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond repute
Wink
I'm not familiar with the denon mixer, but if it has 2 phono inputs,plug Turntable 1 into phono 1 of mixer and the same for turntable 2 into phono in of mixer.The outputs of your misxer go direct into the "AUX or CD IN" of your amp. Then hook up your
speakers to the amp's speaker terminals and your'e ready to go.
Old 05-18-2000
Newbie
Wink
thanks much!
i have one question: will any speakers work with any amp? are there special connectors? etc etc?
thanks again..
Old 05-18-2000
MISTERQCUE's Avatar
Wink
Can you describe what type of speaker terminals your amp has.Also what is the Ohm impedance of your speakers.Is it 2-4 or 8ohms? For example, if your amp speaker terminals indicate only 8 ohms @150 watts and your speakers are 4ohms @ 150 watts, you will most certainly blow out your speakers hi-volume levels.
Old 05-24-2000
Boris Boris is offline
Newbie
Boris is on a distinguished road
Thumbs down
Actually, thats wrong.
You have to find out the impedance (ohms)of your speakers. Then find out what your amp can run at. If the impedance of your speakers is lower than what your amp can handle, you're sure to overheat you amp.
Most home amps can go down to 8 ohms. Most Car amps and professional amps can go down to 4 ohms, sometimes even 2 ohms!
There is an advantage to using speaker with less of an impedance, if your amp can handle it. You're sure to put out more power.
Impedance is resistance. The less resistance your speakers are creating, the harder the amp will work to put out more power. If your amp is not capable of working that hard, it will overheat.
As far as blowing out your speakers goes, know their limits. Don't worry about that in regards to impedance. Worry about your amp.
Old 05-24-2000
MISTERQCUE's Avatar
Wink
My bad! Boris your'e correct. I had it backwards. Need to leave them Budweisers alone!
