Transposing a note in Sonar less than a semi-tone
Is there any way to raise the pitch of one note in an audio clip about a half semi-tone? I have a good vocal take with one slightly off note. The rest are on and I know I'll never get a take that good again. I can't reproduce the compression, eq, and reverb when I tried overdubbing because I never wrote down the settings. So, the overdub has a different "amibience". The transpose function only goes in semi-tones increments. Thanks.
Antare's Autotune
You may want to check out Cakewalk's Auto-tune 3.0. I haven't used it but apparently it's supposed to fix the problem that you are having with adjusting tones.
http://www.cakewalk.com/Products/Antares_Autotune.html Hope this helps. Dick |
Can't you just use the Cakewalk Pitchshifter on that note? Just put in the new pitch in % of the original pitch, and experiment with some settings...
Two wrongs don't make a right, but two Wrights once made an airplane... |
Autotune, RBC Voice Tweaker or OB Tune are the tools that are really designed for this type of application.
If you don't want to invest in another program, pitch shifter *might* work OK on just a single note. (The Transpose command, I think, is designed for midi rather than audio.) |
Skip the obtune I like an idiot jumped on it because of the price and was sorry.It only sounds good with the mildest of settings.
On the other hand I tried a demo of autotune(which you should do)and thats the real deal baby! You get what you pay for. Last edited by acidrock; 04-12-2002 at 20:17.. |
Thanks for all the great tips. I'll download the Autotune demo and try it.
Another way to do it
Without having to redo the entire track, You could punch-in and record just that section that's messed up. It would probably sound better if you punched in for the entire verse though just so it doesn't sound like a cut and paste job.
http://homerecording.com/bbs/showthr...+and+recording This sounds like the same scenario but with the vocal track instead of an audio track. Dick |
...or just insert a really loud splash-cymbal there..
sorry. |
