Old 04-06-2002
UncleHerb UncleHerb is offline
Newbie
UncleHerb is on a distinguished road
Question panning overheads
do you guys pan your overhead drum mics hard left and right? when i do this it sounds unnatural and cymbals and hihat are too "stereo" ... should i be panning them less hard? or maybe this is a phase issue ? i never had this problem with my old drum machine but live drums are a diffrent animal
Old 04-06-2002
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
You should go with what sounds good. What position are the overheads?
I go with a pair of earthworks omnis near the drumers shoulders, and used to use xy over the kit. In both cases I would pan anywhere from full pan to 10-2, depending on how much spread sounded good. About 9-3 gets used the most often for me.
Wayne
Old 04-06-2002
shackrock's Avatar
shackrock shackrock is offline
1K Silver Member
shackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond repute
in my case i just stick with the 2 overheads at the same hieght levels...and do it where it looks good to start. space them as evenly as possible, as middle as possible, etc.
then i listen and rearrange as neccasarry (not enough right whcih in my case is way to the right of the set, so i simply move it over). then i USALLY pan hard right/left. (highhat side left, floor time side righit). really i think just experimenting is the best way to find out. record a ton of diferent ways, then listen to them over the next day or 2 and pick your favorite.
Scott Solo
Old 04-06-2002
Shailat's Avatar
Shailat Shailat is offline
Period
Shailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud of
They might sound too "Stereo" depending on taste, arrangment (spares or full), how much bleeding you have in other tracks.
There might be a phase problem. You'll have to move them closer if the phase is overwhelming.
There is no problem with panning them less hard. It's a matter of taste
Old 04-06-2002
Sonixx's Avatar
Sonixx Sonixx is offline
1K Silver Member
Sonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond repute
Re: panning overheads
how far apart are your mics?...bring them closer together...
Old 04-06-2002
fenix fenix is offline
1K Silver Member
fenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond repute
I've always panned according to how close my overheads are to each other. If they are close, I usually hard pan...and they don't sound too stereo b/c they are close. If they are far away, i'll do the 9o'clock 3o'clock thing.
Old 04-07-2002
Newbie
im using 2 mxl 603s aimed straight down 3 feet apart and 2 feet 2 inches over top of the cymbals so maybe thats too far apart... are they too low as well?
thanks for all the advice i look forward to trying out some of your suggestions
Old 04-07-2002
Sonixx's Avatar
1K Silver Member
i like the imaging using a mic bar which places the mics about 6 inches apart. if placed over the drummers head i point the mic that's closest to the floor tom at the hi-hat and the other at the floor tom (almost like a Coincident Mic Pair but not as angled). point the mics straight down at the kit (mormally mic body is parallel with the floor), then angle them about 15° towards each other.
Old 04-07-2002
<im using 2 mxl 603s aimed straight down 3 feet apart and 2 feet 2 inches over top of the cymbals so maybe thats too far apart... are they too low as well? >
I find this boils down to finding a drum kit image that wants to pull me in two directions at once; wide enough to sound fairly spread out on the top end (useually not going for the 180' tom rolls), but narrow enough to set the kit 'back' width wise to control the distance aspect, and/or at least not have the hat too far left (or right).
So part of the question is, what roll do the o/h's play in your setup? Are they the primary kit mics or mainly to get the cymbals?
As you get closer to 'xy' it gets less phasey and more coherent (part of your 'too stereo' effect?), but mic distance still controls width (initally, befor panning). 'Cymbal' mics can also be pulled back or out to hide the hat a bit.
Most of my experience is with two mics getting the whole kit (except for kick and snare mics). I would think you might want to pull them up and to the front a bit if ther're for the cymbals, or tighter and maybe back if ther're the 'kit'.
Wayne
Old 04-07-2002
Sonixx, that sounds like an interesting way to go, with a bit of spread on the mics, but at a narrow angle.
Do you also add tom mics? I ended up going lower and from behind to get me closer to the drums, but I'm also needing to get some isolation, as I'm not in a dedicated drum room.
Wayne
Old 04-07-2002
Sonixx's Avatar
1K Silver Member
yea...i use tom mics (one per tom), but i mix them in sparingly.
i usually mic with this setup:
1 kick
1 snare
1 per tom (3 for my kit)
1 hi-hat
1 ride cymbal (if i have to choose between the hi-hat and ride i choose to mic the ride)
2 overheads
  #12
Old 04-16-2002
Downside Studio's Avatar
Downside Studio Downside Studio is offline
Have hole in sock..
Downside Studio is just really niceDownside Studio is just really niceDownside Studio is just really niceDownside Studio is just really niceDownside Studio is just really nice
Audience panning or drummer panning?
the long lived discussion, how should I pan the drums? From listeners point of view or drummers point of view.
I personally do the first, but a very very stoned person convinced me the other can be correct aswell.
Whenever I'm really stoned, I put on a record and start drumming my little airdrums. It keeps confusing me if I have to do it mirrored'
Who can argue with this?
Downside Music Productions
http://www.downside.nl
  #13
Old 04-16-2002
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
Talking
Dude, you need to check in to rehab.
  #14
Old 04-16-2002
FenderTL5 FenderTL5 is offline
Newbie
FenderTL5 is on a distinguished road
Just a question for clarification:
"..pair of earthworks omnis near the drumers shoulders, and used to use xy over the kit.."
If you place 2 omnis in an XY pattern, aren't you recording in mono? The polar patterns would overlap so that panning would produce essentially nothing. It is my understanding (& experience) for the XY configuration to be effective in recording stereo, the mics must be directional.
  #15
Old 04-16-2002
Yes, the xy was with card's. Although some omnis are directional enough in the highs to be pointed- read that somewhere, probably with large diaphrams, using them instead of cardioids.
Wayne
  #16
Old 04-17-2002
darrin_h2000's Avatar
darrin_h2000 darrin_h2000 is offline
darrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond repute
Interesting thing to consider is when you are going with hard rock with alot of ambitious drum work, panning form the drummers point of view is a great idea. Sometimes Ill even find myself "air drumming" when stuff is setup in this fashion.
But for Jazz and blues where I consider drums to be more for time keeping audiance point of view works ok for that. "air guitar" is a little more dominant for this listening.
wayne
  #17
Old 04-18-2002
darnold's Avatar
darnold darnold is offline
1K Silver Member
darnold will become famous soon enough
Cool
Well, just from my experience. I noticed from previous drum recordings that i tend to not have enough stereo spread on the overheads when i get them on a homestereo or car stereo. Then when i listen to "professional" mixes the overheads usually sound pretty extreme in the stereo spread. However, im not really sure about this, and im going to be doing some experimenting with this this coming saturday. But this is what i feel, i think the stereo field should be as spread apart as you can get it with the overheads, as long as it is not deductive to the sound quality or have other problems associative. This will give much more distinct seperation within the individual drums. But thats all a matter of taste also.
I recommend recording some other stuff in the mix, like bass and guitar, and do a decent mix, then expirement and see how it sounds when you get it on a home stereo and stuff.
Darnold
  #18
Old 04-19-2002
ChuckU's Avatar
ChuckU ChuckU is offline
RIP DAFDUC
ChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond reputeChuckU has a reputation beyond repute
I'm using omni's (the legendary ECM-8000's, and since so many on this BBS use them I thought I'd chime in). I have them panned hard right and left. Placement as follows:
Six feet apart from each other pointed at the floor. 18-24" from top of cymbals.
Even with the hard pan, the sonic separation is not exagerrated, but rather "real."
"Don't taze me, bro. Don't eeeeyyaaahhhh...."
