Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 04-01-2002
timandjes timandjes is offline
Senior Member
timandjes is on a distinguished road
Unhappy Great sound in headphones, not so great everywhere else?
I thought I saw a similar question to this a while back somewhere on this sight but now I can't find it. I recorded our band on my Tascam 414 MKII. At mixdown, in the headphones, everything sounds crystal clear & great. Then I put the tape in a couple of other tape players and for some reason, there's a big difference in the sound quality. It seems dull and less clear & bright.....Any suggestions?
Old 04-01-2002
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
If you tracked and mixed using headphones only, that is EXACTLY the kind of results I would have expected.....
Bruce
Old 04-01-2002
slkeen slkeen is offline
Senior Member
slkeen is on a distinguished road
I'm no pro, but headphones are good for monitoring your tracks, not mixing down. Everything sounds good on headphones, like you discovered. Try mixing on your home stereo if you don't have studio monitors, you'll get a more realistic sound. I use my home stereo and set all the treble, bass and loudness controls to flat or 0. Keep the volume up quite a bit and mix away! This is not the best set up, but much better than headphones.
Old 04-01-2002
Originally posted by slkeen
I'm no pro, but headphones are good for monitoring your tracks...
Yes... but only AFTER you've made decisions on tone and timbre using SPEAKERS.
Bruce
Old 04-01-2002
Senior Member
How to get the best sound in studio speakers
At the risk of revealing how little I know about PA equipment, I have a pretty cheap set-up @ home, (an 80 w Realistic amp & a couple of old realistic speakers). My band also does some recording @ Church where we have a 500 w Peavy amp and a couple of big new Nady speakers. In both places, tapes played sound heavy on bass tones with little treble. What would you suggest to help me know I'm adjusting everything properly? Better speakers? Any suggestions for someone on a tight budget?
Old 04-01-2002
Track Rat's Avatar
Total Gear Slut
Don't mix through the PA. On the system you WILL be mixing on, play a bunch of commercial CDs through it that are simaler to the material you're going to mix. Listen very carefully how this system resolves bass and highend content and try to memorize how it sounds. As you're mixing your material, periodicly pop in some of the CDs again and compare how they sound next to what you're doing. When you think you've got a mix, make yourself a CD or cassette copy and try it out on as many different systems as you can to see how it's holding up. If you hear problems, tweak and try again.
Mike
Old 04-04-2002
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow On a cassette, azimuth comes into play when you move the tape between machines.
If the tape sounds good on the deck it was recorded on, but not so good on other tape players, it's probably the difference in azimuth, head alignment, that's causing the relative drop in sound quality.
Also, ditto, I agree that you'll get a better sound overall by mixing down on a decent reference monitor, instead of phones. Phones do sound great, but they can skew the mix a little, 'cause they sound different than most monitors. Not bad, just different.
/DA
