Old 03-29-2002
arc76 arc76 is offline
Newbie
arc76 is on a distinguished road
Setting up DAW?
Hi,
I would just like to know the "ideal" way to setup my current equipment configuration so i can record a decent demo, since i am new to this.My equipment is as follows:
Mesa triple recto
4x12 cab
Korg x-3 synth
shure sm-57
senn e825s
Behringer mx602a (4ch mixer)
Steinberg Project pack(20bit 2in/2out audio card and cubasis vst software)
P2 350mhz,64meg ram,8.4gighd
Looking to lay multiple guitar tracks down, then add drums/add'l instruments with the x-3.The current soundcard doesn't have midi cabability.How would you recommend i hook all this up,i'm lost!.Do i need add'l equip?
Old 03-29-2002
M.Brane M.Brane is offline
Part-time amateur AE
M.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond repute
Looks like you've got the analog input covered. I would want at least another 64MB of RAM (or more- it's CHEAP) & a second hard disk (7200RPM) for the puter. Sorry, I don't do MIDI so I can't help you out there.
Old 03-30-2002
Stealthtech's Avatar
Stealthtech Stealthtech is offline
LOGIC ABUSER
Stealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond repute
Since you only have 2 inputs on your soundcard you can track one at a time or if multitracking use your mixer. As far as midi goes, you said you have no interface on the current card which we dont know what card that is, but if you also still have your system stock card like a soundblaster, this should have midi connects and can be used along with your recording card with no real problems.
Old 03-30-2002
Newbie
Re:Setting up DAW
Thanks for the input so far,
Stealth-the audio card i am using is 20 bit w/2 analog in/out and 1 digital output. I purchased it along with Cubasis VST ver.3.7(Project Pack).My original card was a soundblaster 128.I would like to take advantage of having both soundcards installed so i can use the midi in of the sb card but how do i go about doing that?will i have any conflicts between the two cards?I have a Korg x-3 synth that i would like to connect to the sb via midi, The cubasis vst software includes a virtual bass and virtual drums.Would i be able to take advantage of those instruments by using my synth as the controller?Do i need a midi interface for that?Cabling?
Sorry about all the questions-just trying to get it all together.
Old 03-31-2002
LOGIC ABUSER
As long as you have a free IRQ you should'nt have conflicts. Sometimes you have to force a device to not share an IRQ, but you wont know till ya try it. Did you remove the SB from your system? The VST's or virtual instruments in cubase can be controlled from your midi keyboard. You will also have a bank of GM soundfonts with your SB that can also be used and controlled from your keys.
When you use your midi interface from the SB you can look in your multimedia settings to set this interface active, and you may have to look in cubase as well for these settings.
