Old 03-27-2002
FiVeL's Avatar
FiVeL FiVeL is offline
Junior Member
FiVeL is on a distinguished road
Wires?
Hello people I had a question about wires. I was wondering is it bad if you have cheap rca or 1/4 wires connected to your instruments? Does it affect your recordings?
Old 03-27-2002
Evildick's Avatar
Evildick Evildick is offline
Dedicated Member
Evildick is on a distinguished road
Poor mans point of view
Until you start dumping serious money into your DAW and home studio, I wouldn't worry about it. Adequate home recordings can be made using RCA's and instrument cables. They aren't going to be pro or semi-pro quality but until you understand every component in your signal chain, it won't really pay off. Do a Google search on 1/4" TS (mono), 1/4" TRS (balanced), XLR, and RCA cables to get a better understanding of what you want. If the hardware that you have doesn't support balanced inputs, then you would be better off spending your money elsewhere.
In a nutshell, wires do effect your recordings. At a beginning level though, this effect is negligable. Understand Hi-Z (high impedance) from low-Z (low impedance) and when those cables are required. This should give you enough to start out with research. Happy searching.
Dick
Old 03-31-2002
xBodix xBodix is offline
Newbie
xBodix is on a distinguished road
you need gold xlr cables....they are good...and they will improve quality....
Old 03-31-2002
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Huh??? Care to elaborate on that pretty general statement?
(and especially on how you connect XLRs to instruments....)
Bruce
Old 04-01-2002
engineear's Avatar
engineear engineear is offline
Senior Member
engineear is on a distinguished road
Obviously Bruce, you don't have a 20oz sledge (aka. XLR to 1/4 converter, both TS & TRS).
Old 04-01-2002
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Obviously he doesnt.... what a dweeb And he considers himself a pro, jeesh.
Old 04-01-2002
engineear's Avatar
Senior Member
Thumbs up
........AND.....add the 20oz piggyback attachment to the original native sledge for those hard to convert XLR to RCA,.......BLAMMM!!!........ "CANON" plug coversions. Your results may vary..........solder.......who needs it, hit the damn thing hard enough and you can arc weld all your connections right to the outboard gear faceplate(always remember to properly ground all connections!). Looks like Home Depot has entered the Pro Audio arena.
Old 04-01-2002
Track Rat's Avatar
Total Gear Slut
I'd like to exothermicly weld my 00(double ought) oxygen free cables to my solid gold plated platinum RCA connectors instead of solder. Is this a good idea? And should I color them green with a majic marker?
Mike
Old 04-01-2002
Thumbs up
You guys fuckin' kill me!
Old 04-02-2002
engineear's Avatar
Senior Member
No.........No...........well almost. You see TR e-thing is correct up to the point of hue. "Hue du jour" is fuscia with a splash of puce a just a hint of magenta............green is oh so trite!!!!!!!!
