Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 03-21-2002
Phloodpants Phloodpants is offline
Junior Member
Phloodpants is on a distinguished road
They've improved the MXL1000! (I think)
I just received my MXL1000 / Fox package from 8th Street.
The MXL1000 has a different kind of windscreen than it used to! There is no more of that tight little ball around the capsule, it is now a foam windscreen that fits tight to the inside of the metal mesh. Check it out...
Compare that to the picture on MXL's website...
That little ball is what Harvey was saying screwed up it's sound! This new windscreen seems like it would not mess with the sound as much. Not that I've done a lot of recording with it, but just by speaking into it I don't hear a lot of difference when the screen is on versus off.
Also, I'm not sure the capsule is the same as the 603 as Harvey had suggested. (With all due respect, Harv. You da man.) MXL's website claims the 1000 uses a 5 micron diaphragm, and the 603 uses a 6 micron. I know the website has other errors, so that might be the case here. Also, the capsule of the 603 seems to have a bit more back venting than the 1000. It has 4 smaller vents, while the 1000 has two larger ones.
What say you?
Old 03-21-2002
windowman windowman is offline
Dedicated Member
windowman is on a distinguished road
Hmm, interesting; thanks for putting in all the work with this.
Old 03-21-2002
B3Nut B3Nut is offline
Junior Member
B3Nut is on a distinguished road
Lightbulb
Hmm....both my brochures for MXL mics state the 603 has a 3-micron diaphragm....the one brochure with the 1000 in it states it's a 6-micron for that one.
Brent Casey'd know for sure methinks....
TP
Todd A. Phipps, his better half Liz, and his silly dog Obie + Honey + Deuce + Weezee
http://www.afterburnerpro.com
http://www.crush-band.com
Old 03-22-2002
Junior Member
Well, the capsule on the MXL1000 has a part number of MXL-C206J, which I think is safe to assume means
Condenser-20mm-6micron-revision J.
The 603 capsule doesn't have any markings that I can see.
