Old 03-07-2002
hanzsprungfeld hanzsprungfeld is offline
Newbie
hanzsprungfeld is on a distinguished road
sonar and tc works
what do you think of this.. i didn't happen to save every 5 seconds today and after i applied a little eq on the bass guitar with tc works parametric eq, one of those damn la la error DLL's happened and sonar kept playing the song until i hit close on the error message.. this happened once before when i closed the plug in control panel for the EQ while the song played.. what gives? bad software? dumb OS?
pentium III 866
1024 mb RAM
good hard drive
motu 2408
Windows ME.... our singer insists it rules.. i've watched it kill the computer at our apartment.. it doesn't fair well with harware.. blah.. help
www.wheelierock.com
Old 03-07-2002
Teacher's Avatar
Teacher Teacher is offline
do unto others......
Teacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond repute
crashes using TC and waves happen to me too...i can't figure out y sometime they occur and they don't....i use XP pro wit 900 mhz athlon....might be cuz of apps running in the background taking away CPU resources at a critical time which causes it to crash
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage
Old 03-07-2002
chuchosay chuchosay is offline
Junior Member
chuchosay is on a distinguished road
I use to have the problem of errors occuring and spontaneous reboots while making certain changes, using Waves or just by pressing the "stop" command. It turns out that for me it was a soundcard driver problem. Here's what you should try:
Download the latest driver for your soundcard from the manufacturer's website--try to get a WDM driver if it is available. Remove the old driver and install the new driver. Delete the "aud.ini" and "ttsseq.ini" files from Sonar's folder. This won't screw anything up--they come right back when you run Sonar. When you run Sonar it should look for you hardware again.
If this doesn't fix the problem, you might have an IRQ conflict. Go to Start/Settings/Control Panel/System/Device Manager and double click on Computer. Make sure that your video driver, audio driver, and USB ports do not share the same IRQ address (a one or two-digit number). It is okay if "PCI Steering" is sharing the same number, though. If they are sharing the same number, then you need to get that fixed.
