Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-03-2002
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Arrow Monitor Comparison - Mixed the same song on 2 sets of monitors (clips included)...
This has all the makings of another subjective "shoot-out" but there ya go.........
Obligatory Notes and Disclaimers
I took this tune and mixed it using Event PS6s with Tannoy Proto-Js as secondaries... this was back in November.
When I recently upgraded my control room monitors to KRK V8s, I was curious about the difference in translation and mixing (especially since the V8s seemed so much more revealing) that I mixed the tune again using the V8s and Yorkville YSM-1i as secondaries.
Both the Tannoys and Yorkvilles were powered by a Hafler P3000 amp.
Now, there will of course be some difference in the mix due to the fact that on any given day, it isn't likely that a person will mix the same song the exact same way twice, even using the same monitors! So the way I approached this is to mix it on each set WITHOUT comparison to the other - I was simply mixing the track as I would have based solely on what I was hearing.
The Clips and My Impressions
I thought about doing this blind, but there's really no point, since I learned what I needed to know from the exercise, and the "blind" factor wouldn't be of any use to anyone else!
As I said, I found the KRKs much more revealing and less forgiving about tonal "strangeness" than the PS6s and comparing these two clips in the control room bore that out...
As well, I found it much easier to translate mixes using the V8s than I did with the PS6s... although the PS6s are quite reasonable monitors - they do have their weaknesses....
Anyways, enough blabbering....
http://207.176.147.104/bbs.nsf/c558e...reAgainPS6.mp3
http://207.176.147.104/bbs.nsf/c558e...ereAgainV8.mp3
Bruce
Old 03-03-2002
mixmkr's Avatar
mixmkr mixmkr is offline
we don't need rest!!
mixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond repute
I hear the biggest differences with the drums...with the hh and snare being more pronounced and crispy on the 2nd version. The overall mix sounds a little brighter too...leading me to think that either you're getting older!(and the ears are losing it due to age), or the little Events push the high end out a little more.
On a side note, I sent a mix to Harvey G. about two years ago, when debating whether or not you could tell what monitors you mixed on, soley by listening to the mix....and he picked 'em...the JBL 4311's that I've primarily been using for the last 20 years. I didn't know that's what he used also, but I found it kinda amazing. I certainly couldn't do it, and lost that debate
Old 03-03-2002
Track Rat's Avatar
Total Gear Slut
Gotta echo mix's comment on the second mix being brighter. The hats in particular which would lead me to the same conclusion about highend response on one set of the monitors.
Mike
Old 03-03-2002
Yes, the PS6s tend to give this glossiness to the highs and I usually ended up with less bright mixes than I wanted, so I had to compensate....
The V8s however tend to tell it more like it is... when I had played the mix from the PS6s on them, I found the PS6 mix sounded muddy and dark, whereas the V8 mix sounded more open and natural, even when played back on the PS6s!
The biggest change I find is that had I heard things on the V8s, I wouldn't have mixed them the way I had on the PS6s. The brightness, the slight muddiness in the vocal, the slight boominess on the bass... all these things didn't show up when monitoring on the Events - but they were very clearly audible on the KRKs though!
Bruce
Old 03-03-2002
LongWaveStudio LongWaveStudio is offline
1K Silver Member
LongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond repute
nice mixes. personally felt that the brass came out a little too much. that track needs some cymbals! where are they?
nice work man.
________________
Long Wave Studio
07980 265366
Old 03-03-2002
nice work man.
Thanks! I only mixed the tracks I had! (I didn't track it...)
I had done a mix with the brass lower, but I didn't care for it -- personal preference I suppose, I like brass that punches through a bit....
Bruce
Old 03-03-2002
Dolemite's Avatar
Dolemite Dolemite is offline
Force of Nature
Dolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond reputeDolemite has a reputation beyond repute
FWIW, I like the PS6/Proto-J mix.
The V8 mix sounds brighter/thinner.
Old 03-03-2002
You're a freak Dolemite!!!
Bruce
Old 03-03-2002
Dolemite's Avatar
Force of Nature
Don't I know it!
Just had to go against the grain on this one
Old 03-03-2002
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
Where's the bass drum? Don't tell me the drummer was playing with one of those "jazzy" sets (?) That's what I'm guessing, but if not, then I'd say both monitors may have been too strong in the 60-80 hz region . . . but I'm guessing that was probably just the style of the music, right? Good mixes, though. Great high-end detail on mix #2.
Old 03-03-2002
Listen on a REAL monitoring system, and you'd hear the kick drum, chess!
Actually though, if I took it out of the mix, you'd definitely notice it missing... it is there reinforcing the bass, exactly where it needs to be!
Bruce
  #12
Old 03-03-2002
chessrock's Avatar
Banned
Bruce
That's what I was afraid of -- if "real" monitors are needed in order to hear it, then that pretty much leaves out only 99.9% of the consumer listening market.
Still, I know a bass drum with a Jazz head on it (usually the Yamahas) when I hear one, and that one sounds pretty jazzy. It works for that syle, though, Bruce. Sounds rather more percussive, if you ask me. Although I wouldn't go so far as to say it "supports" the bass, at least I don't hear it getting in the way of it. Nope. Pretty far out of harm's way of anything in that mix.
I was going to say you should give it to me for mastering: I can go crazy with the maxx bass plugin and pump the shit out a' that kick! )
  #13
Old 03-03-2002
Originally posted by chessrock Although I wouldn't go so far as to say it "supports" the bass, at least I don't hear it getting in the way of it.
As I said, if I actually took it out, you'd hear it missing right away! And I DO happen to know what I'm doing with kick/bass relationships - I spend a lot of time on that particular aspect of mixing because it is a critical component of the track's rhythm!
Besides, I don't know what you're talking about chess, because I can clearly hear it even on my cheap ass computer speakers! Do you have the lo-shelf EQ on in "cut" mode or something???
I wasn't involved in the tracking of this tune in any way, so I have no idea what was used as far as instrumentation or even signal chain!
Bruce
  #14
Old 03-03-2002
Originally posted by chessrock I was going to say you should give it to me for mastering: I can go crazy with the maxx bass plugin and pump the shit out a' that kick! )
OK... but only if you put a sh*tload of reverb on it too!
(just teasin' dude!)
  #15
Old 03-03-2002
mixmkr's Avatar
Bruce
I bet the kick was tracked thru a POD to 'simulate' a jazz set...but was really off a rock set.
  #16
Old 03-03-2002
Dolemite's Avatar
Force of Nature
Don't forget the BBE!
  #17
Old 03-03-2002
chessrock's Avatar
Banned
I will bet you $20 that the bass drum had the words: "YAMAHA" written in big white letters on the front of it.
  #18
Old 03-03-2002
Whoopysnorp's Avatar
Whoopysnorp Whoopysnorp is offline
Huh huh..."member"
Whoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond repute
He might have just been emulating a different drum cabinet.
  #19
Old 03-03-2002
Ha! No Aural Exciter of any kind was used in the making of this mix!
Bruce
  #20
Old 03-03-2002
Dolemite's Avatar
Force of Nature
Bruce
HOLY SIGNAL ENHANCEMENT, BATMAN!
Our evil adversary Blue Bear has abandoned his secret weapon!
  #21
Old 03-03-2002
CyanJaguar CyanJaguar is offline
Three Thousand and Counting
CyanJaguar has a reputation beyond reputeCyanJaguar has a reputation beyond reputeCyanJaguar has a reputation beyond reputeCyanJaguar has a reputation beyond reputeCyanJaguar has a reputation beyond reputeCyanJaguar has a reputation beyond reputeCyanJaguar has a reputation beyond reputeCyanJaguar has a reputation beyond reputeCyanJaguar has a reputation beyond reputeCyanJaguar has a reputation beyond reputeCyanJaguar has a reputation beyond repute
as much as I wanted the cheaper combo to win, I must say that the v8 had a more pro mix overall.
The most important thing is, of course, the vocals, and the v8 mix presented a much tighter image, albeit a bit on the midrangey side.
THe brass was also not as loud hence not as annoying.
My mind is made up. Dont confuse me with facts.
The kind of girl I want, wants the kind of guy I'm not.
  #22
Old 03-04-2002
Meshuggah's Avatar
Meshuggah Meshuggah is offline
Commie Bastard
Meshuggah is a name known to allMeshuggah is a name known to allMeshuggah is a name known to allMeshuggah is a name known to allMeshuggah is a name known to allMeshuggah is a name known to all
Damned Bruce... I thought the small probs I heard with the first mix was mp3 artifacts.. then on the KRK mix, it's all gone... Drums have better presence and tone. The vocals sounds WAY more natural, and overall, it's a more open mix. And one'd have to be deaf not to hear the kick.... the bass is wonderful...
Great job, Bruce. And thx for the interesting post.
I want [img]-code in the sigs. now!!!
  #23
Old 03-04-2002
iqi616's Avatar
iqi616 iqi616 is offline
Yet another Mike
iqi616 has a reputation beyond reputeiqi616 has a reputation beyond reputeiqi616 has a reputation beyond reputeiqi616 has a reputation beyond reputeiqi616 has a reputation beyond reputeiqi616 has a reputation beyond reputeiqi616 has a reputation beyond reputeiqi616 has a reputation beyond reputeiqi616 has a reputation beyond reputeiqi616 has a reputation beyond reputeiqi616 has a reputation beyond repute
Thumbs up
Thanks for a great topic.
  #24
Old 03-04-2002
nwsoundman's Avatar
nwsoundman nwsoundman is offline
Vintage Gear Junkie
nwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond repute
One question Bruce,
How much much time did you have in front of each pair of monitors? Example: one year PS-6's, three months KRK's.
  #25
Old 03-04-2002
Beathoven's Avatar
Beathoven Beathoven is offline
Certified Lunatic
Location: Lemme school ya'll permanently like a motherfuckin' tatoo!
Beathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these partsBeathoven is infamous around these parts
Shit Blue Bear, that's a f***in' great song!
I'm mostly in rap but damn! This song played almost an hour on my computer while I was reading on the board... and I liked it!
Keep up the good work bro!
Beathoven
(P.S.: I too see the difference between the monitors. The highs seems more clear in the second mix.)
