Old 02-26-2002
Todzilla's Avatar
Todzilla Todzilla is offline
Force of Nature
Todzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond repute
Question Bass Trap Design Sanity Check
Gradient Pressure Fans,
Here is my proposed design for a corner bass trap. I think I may have the concept articulated, but I yearn for some feedback.
The view is from above, showing a big triangular shaft of space, closed at the top, with a thin sheet of plywood and some insulation behind it to tame things.
I thought the triangular shape would give it more of a broadband low-end application.
Did I get it right?
BTW, I'll build some cylindrical ones for moving into specific locations.
Thanks
Insect Massage Therapist
HUGE sound generation & capture facility
http://www.toddejones.com
Old 02-26-2002
longsoughtfor's Avatar
longsoughtfor longsoughtfor is offline
Searching for the sound
longsoughtfor is on a distinguished road
Todzilla - I would add rigid insulation on the corner walls inside the trap as well. Aside from that, the important thing is that the whole thing is sealed against the wall, floor and ceiling to create the pressure gradient.
Cheers
Kevin.
Old 02-26-2002
Todzilla's Avatar
Force of Nature
You mean like this?
Old 02-27-2002
Yup.
Old 02-28-2002
John Sayers's Avatar
John Sayers John Sayers is offline
Solar Power!!
John Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond repute
What you are building here is a panel absorber which will be tuned to the frequency = to the resonate freq of the plywood.
Here is the solution I sent sjoko for the rear of his control room.
Sjoko rear corner
cheers
john
Old 03-01-2002
Todzilla's Avatar
Force of Nature
John,
Thank you.
Wow, I guess I misunderstood the whole broadband bass trap thing. I am trying to interpret your plans and I have a couple of questions:
1. Do you mean that all the gaps between the slats are 1/8", or is there some variation that ensures different frequencies are trapped?
2. Orientation of the 2" X 4"s - are you showing the 2" side as the side which will face the room?
3. Are your dimensions of 2" X 4" lumber exact? Because here in the states, what we call a 2X4 is more like 1.5" X 3.5"
4. Would you loosely fill the void with insulation, or leave some air?
I am intrigued and somewhat intimidated by your design, but it looks fairly easy to construct with just 2X4s.
Do you suppose it'll still work in this hemisphere where sound rotates clockwise? ;^)
Old 03-01-2002
Solar Power!!
Yes it's a slot resonator with the 2 x 4 using the 4" depth and the 2" facing the room. Sjoko and I discussed using 1" plywood instead which would give more diffusion and produce more slots. I'm not sure which one he decided to go with.
Yup fill the cavity with insulation. Good place to throw any leftover insulation offcuts you may have during construction.
The 2 x 4 is a standard construction size. If it's dressed all round it may have a 1/8" taken off by the plane but I would expect it to be 2" x 4". can't see how it could be dressed down to 3.5"??? Note the sizes go up to 6" x 2" to get the depth for the low frequencies.
cheers
john
