playback/recording sssttttuttering
Hey maybe some of you vets can help this noob out. I'm having trouble with stuttering during playback and recording after 3 or 4 audio tracks. neither meter gets above 10% and the actual data is fine just stutters when reading it. I was overclocking but set it straight and problem didn't go away. I guess it is just a matter of figuring out the best audio settings for my specs (i.e. buffer I/O buffer size, enable/disable read/write caching, buffers in playback, aux busses). If you need anymore info let me know.
Cakewalk Pro 9 Roland U-8 win98 1.0 AMD ghz 256 ddram |
first of all, go through the steps described in cakewalk's help file.
if that doesn't solve the problem, come back here, and use the search function. i'm sure you'll find a lot of threads with configuration tips, and walkthroughs to solve stuttering problems. check out the faqs on cakewalk.com too, and there's also a couple of articles on http://www.prorec.com about tuning windows for audio. if none of it helps, post again, and make sure to email cakewalk, even though they'll take a week to reply. hope this helps. adriano |
thanks for helping me get focused a little better postalblue. i'll do some work and see what i can't find.
Thanks again postalblue. All I needed was some windows tweaking and everything works absurdly well. I opened a big project and threw on about 30 effects and didn't get stutter one. Thank you and thanks to everyone who makes this forum such a priceless tool.
anytime. glad i could help.
adriano |
