Anyone using Auralex Acoustics?
How good are the Max-Walls for vocal booths? Does the foam hold up?
Good for portable use or in a room that's intended for other uses after a recording sessions,by the way, one recommendation you only need to post your question once or the flame department will be all over you my friend!! Welcome to the bbs........
Didn't there used to be a guy on Harmony Central named C1st that constantly got kicked off?
Sorry I can't help you on your aurelex question. Just curious. Oh! And welcome to the bbs. You will find it a invaluable scource of knoledge and redundency and redundency and redundency. But the people will ALWAYS help you out. ![]()
"601 is code for 'Cannot Be Analized'" |
Re: Anyone using Auralex Acoustics?
Though, you could make them yourself. its nothing more than a few pieces of plywood with foam glued to it with a base. And then you can make whatever size you want ![]() |
